Final Cut, while powerful, is so slow it makes me want to pull someone else's hair out.
Also, with each crash, if I started another clip with my hand in front of the lens for 1-2 seconds, then uncovered and returned to the scene, regardless of detail, the clip did not fail. Yay workarounds!
Where on earth did you even come up with such an idea as to try a method like that? Or was it out of a production book somewhere?
I'm trying to understand the difference between this patch (100 Mbps Max Latitude) and the Blackout-Powell patch. Correct me if I'm wrong, but if my plans are to shoot in AVCHD mode 1080p at 24 fps and I want to achieve the best latitude possible at average bitrates the 100 Mbps Max Latitude patch is the better of the two; however, if I want to shoot in the same mode, AVCHD mode 1080p at 24 fps and I don't care about latitude only achieve the highest detail or average bitrate possible then the Blackout-Powell patch is the better choice, right?
In the future please only post the same message in one thread at a time. However, for both of those purposes, I'd use Max Latitude. In my opinion, Max Latitude is best for 1080p24 if you don't mind sacrificing 720p60 for 720p30. Blackout-Powell is the best if you want to retain the slow motion capability of 60 fps SH mode.
I apologize for double posting, I just figured since it applied to both threads I would get an answer from someone following either this thread or the other. That said, because I got an answer on this thread I went ahead and removed the post from the other.
Thanks.
I tried to play it in camera and tv. The results are the same. Tried to record in A, S, and P mode without any difference.
* I recommend using the camera to format your SD card at the start of each shoot, to guard against SD card memory fragmentation.
in the OP, lpowell stated:
Can some one elaborate on this? In what context does "each shoot" mean here? If I'm on vacation with a 32GB card.. I'm going to keep shooting across multiple days until the card is filled.. I won't have the luxury to dump the content and reformat card. Is this fragmentation problem serious?
Also, does anyone know if this patch is compatible with the newest version of the Ptool and the previously unhackable bodies?
Yes, it works. I installed it yesterday on a GH17. It made 24p/progressive files and higher bitrate.
