UPDATED to Version 2! INI files for the latest version of PTool ready for download
As you've no doubt heard, PTool 3.55d and above have liberated all previously unhackable versions of the GH1. In addition, PTool provides a variety of new patches that I've been able to incorporate into the Blackout-Powell Native 24p Patch, making it more versatile than ever.
To make use of these new features, download the latest version of PTool from the following link:
http://www.gh1-hack.info/ptool3d.zip
For version 2 of the Blackout-Powell Native 24p Patch, I've prepared a choice of two INI settings files that differ only in the settings for the MJPEG 30p modes:
* For use with standard lenses, the standard patch will produce two types of MJPEG videos:
HD mode: 1280x720 HD videos in 4:2:2 color depth, with peak bitrates up to around 60Mbps.
VGA mode: 960x720 iPad-compatible videos, with peak bitrates up to 30Mbps.
* For use with anamorphic lenses, the anamorphic patch supports two different squeeze ratios:
HD mode: 1920x720 videos optimized for 1.5X anamorphic adapters, with peak bitrates up to around 50Mbps.
VGA mode: 1920x720 videos optimized for 2X anamorphic adapters, with peak bitrates up to around 50Mbps.
Blackout-Powell Native 24p Patch Settings Files
The zipped INI files below can be used to apply complete patch settings to firmware loaded into PTool 3.55d. To use, unzip the INI file into the same folder as the PTool application. Launch PTool and load the firmware for GH1 v1.32. The settings contained in the INI file will automatically be installed in the "B" button at the bottom of the PTool main window.
Note that with these PTool Settings files, you may at any time re-install the original Panasonic GH1 v1.32 firmware into the camera. You may also copy each type of patched or original firmware to separate SD cards, and use them to quickly switch between patches as often as you like.
View attachment Blackout-Powell Native 24p Standard Patch v2.zip
View attachment Blackout-Powell Native 24p Anamorphic Patch v2.zip
Read on for updated background information on these patches:
The New Sensation
Exactly one year ago, my (first) Panasonic GH1 arrived from Amazon. Like many high-tech prosumers, I had tried taking "home" videos on everything from Sony Hi8 Handicams, to Canon DV Camcorders, and even Apple iPhones. None of this moderately expensive gear had produced anything remotely professional-looking to my eyes, and the Firewire file capture experience made it all seem so tedious.
Nevertheless, I'd heard about DSLR HD video over the past year and wanted to see some for myself. My background in cinema surround sound and audio/video codec development led me to be fairly skeptical of how good a consumer camera like the GH1 could possibly be. But the specs looked promising on paper, I had an old stash of Canon FD lenses I was eager to play with again, and the availability of Quad-core PC's and Terabyte hard disks made the timing totally right.
My initial test shots on the GH1 in fabulous Full-HD looked immaculate on my widescreen HDTV, at least compared to my aging DVD collection. I was impressed enough with this remarkable little camera to videotape a friend's 3-piece blues band at a dingy local dive. That sobering experience was the beginning of...
The Prosumer's Complaint
The stock GH1's video quality is really not that bad, so long as it's daytime and neither you nor the subject actually moves very much. While I was experienced enough to choose the right lens and exposure for a dimly-lit nightclub, I was not prepared for the muddy low-light macroblocking the GH1 produced at its worst. I seriously considered shipping it back to Amazon for a refund.
We all know what happened next - Vitaliy hacked open the GH1 and gave us an untempered taste of what the little box could do. Well, might be able to do... with the right patch here, a subtle tweak there... and a dose of heady 100 Megabit excitement, which led inevitably to...
The Neverending Worry
Unfortunately, the impressive bitrates granted by the GH1 hack come with some unsettling hazards that can potentially ruin a crucial shot. The first hack I published, the Reliable In-Camera Playback Patch, resolved a great many of these concerns with a relatively conservative increase in video bitrate, along with 4:2:2 color depth in MJPEG mode.
One highly desirable feature I was not able to deliver was to banish the curse of interlaced pulldown that confounded the GH1's FHD videos. While the Native 24p patch Vitaliy provided would remove the interlacing from 1080p files, it was disturbingly prone to corrupting the video stream and provoking fatal lockups during recording. Month after month, innumerable dvxusers searched to no avail for the elusive secret to achieving a reliable Native 24p patch. But even when a video appeared to record without error, it might nevertheless harbor damaged or empty frames which could produce subtle glitches during playback:
Indiana Blackout and the Holy Grail
The screenshot above was produced by cbrandin's invaluable Stream Parser, and shows one of the insidious hazards of the Native 24p patch. Among the stream of red I-frames and blue P-frames are several gaps - empty frames which the AVCHD encoder failed to record. I extracted this sample from a delightful video contributed by dvxuser Blackout, who described its background here:
Creepy Denver International Airport
Sporatic frame drop-outs of this sort often go unnoticed, as they typically cause recording failures only when they become persistent. Blackout has posted numerous samples of high-quality Native 24p videos shot using a hand-crafted patch of his own. Intrigued by his enviable Native 24p track-record, I approached Blackout with the prospect of combining his well-honed PTool settings with the arcane stabilization techniques I'd devised for my previous patches...
Lumix Raider: The Last Revelation
While I wasn't able to recruit Angelina Jolie to star in this epic reveal, I did find a nice set of tombs where she would've looked stunning:
This technically flawless video was taken in Native 1080p24 mode on a hacked GH1 with a Leicasonic 14-50mm f2.8-3.5 zoom lens, mounted on a Manfrotto 560B monopod. Isn't it great what fabulous toys we have to play with these days?
Blackout-Powell Native 24p Patch Downloadable PTool INI Files
*** WARNING ***
The Blackout-Powell Native 24p Patch will not work properly with previous versions of PTool.
The best way to insure that you have the latest PTool release is to download it directly from the following link:
Download PTool here: http://www.gh1-hack.info/ptool3d.zip
The zipped INI files below can be used to apply complete patch settings to firmware loaded into PTool. To use, unzip the INI file into the same folder as the PTool application. Launch PTool and load the firmware for GH1 v1.32. The settings contained in the INI file will automatically be installed in the "B" button at the bottom of the PTool main window.
The New Sensation
*** WARNING ***
