Brook Willard said:Great!
Do I see a RED-DRIVE and the optical RAW port on the camera simultaneously?
Jannard said:Mini-RAID connects to bottom of back panel... NOT the optical port. It cannot handle RAW, only REDCODE.
Jim
If I'm not mistaken (though these things change all the time), you either connect the optical port unit or the onboard flash unit (perhaps what you thought was the "blank cover?") to the side of the camera (and it hasn't been announced if they both ship with the body - we just know it comes with 32 or 64 gigs of flash). I don't think there's a "dummy panel" you put on if you aren't using the optical or flash units (ie, if you're just using the mini-RAID).Brook Willard said:I think I'm so used to seeing the blank cover on the left side of the camera that I expected something else to bolt into place when the flash and optical units aren't being used.
