I think I watched the same clips. Do they indicate which frames were shot in the s35 mode and which in full frame? To the best of my concentration, that info is missing.I've watched the sample videos a couple of times now, and I'm worried about the bitrate.
Maybe it's just a youtube thing, but I'm not seeing that on many other videos shot with other cameras, and 100 Mbps is low for 4K if you're not using H.265. ...
Yes, a huge auto-focus improvement and an oversampled 4K, similar to F65 (albeit using a different Bayer mask and fewer pixels).PDAF and "true" 4K in cropped mode. Those 3 things aren't really insignificant...
Well, using the process of elimination - this is the same bit rate as GH4, roughly the same codec but vastly more data (and, presumably more processing power), so when compressing from 42 MPX down to 8.3/8.8, a lot of more data needs to be discarded and/or processed compared to a native 8.8/8.3, so I can see artifacts introduced during that process too.The pulsations I talk about are caused by the codec (either the camera's codec, or the youtube codec, or something else that may have been used in the middle). It has nothing to do with the sensor, or how much info is thrown away...
Do we know it skips every 4th line?... Also, on FF mode, it seems the a7R II does lineskipping, so it doesn't compress 42 Mpix to 8 Mpix, it reads 8 Mpix and saves 8 Mpix. In any case, discarding those other 36 Mpix wouldn't create this kind of artifacts. This is clearly a long-GoP kind of artifact.
That might not be a bad thing if they get the base ISO below 3200.
Base ISO for A7R II is 800 for Slog-2.
I used it all day today.
To quote myself, it probably does but it could theoretically skip every 2nd too, thereby getting slightly more than the 14 MPX in the s35 mode or around 16.5 MPX. In that respect, it'd both bin and oversample at the same time.Do we know it skips every 4th line?
I believe it only reads half the rows and half the columns, so, a fourth of the photosites. Because that leaves you a matrix on which you can do a 1-to-1 debayer to get a 4K image. But really, no idea. All I really know is that Sony says it doesn't line skip on APS-C mode, and says nothing about FF mode. From there on it's my speculation...
You Samuel and everyone here... Let's spill out the beans!@FaymusMedia:
Please tell!!!
Do you see any codec issues? How is DR? How good are the high fps modes? Really, anything you can share, I'd love to hear![]()
So, if true - the sensor is read 4 lines at a time and then that information is averaged out and, if it changes several times per frame, that's what produces the artifacts.Because there is no mention of a global shutter, Sony may be using this design they patented last summer:
http://www.thephoblographer.com/201...looks-eliminate-rolling-shutter/#.VX-H2M_BzRY
If true then they are reading 4 lines at a time.
See, I knew there had to be some info I failed to glance at. S35, however, shouldn't have the problems associated with the 42 MPX readout/pixel binning.The title in the video says "S35" so the whole video would have been shot in S35 only.
Have you heard of a camera skipping/binning specific photosites - i.e, fewer reds than blue or something like that - rather than a simple geometric binning? I am wondering that because I saw recently a Image Sensor World post that brought up a new Aptina patent where the red filter is larger than others.
You've probably seen it already -
http://image-sensors-world.blogspot.com/2015/06/on-semi-aptina-proposes-variable-size.html
And Sony always sounds like S35 is the way to go with this one. Bummer. It's a bit too expensive for an APS-C camera. a7000 where are you???Let's see what the early reviews say. Bloom seems to not like the FF.
With A6000 getting a XAVC S upgrade, I wonder if a better codec or a higher recording bitrate is in the cards for A7R MK II somewhere down the road. They've obviously crippled it to protect FS7 with the 8-bit internal/external and 100 Mbps only. The rest depends on its sales figures, I suppose.And Sony always sounds like S35 is the way to go with this one. Bummer. It's a bit too expensive for an APS-C camera...
