Beautiful!
I obviously can't read the subtitles, but did catch "ND" in one of the subtitles...unmistakable what he's referring to and why
Is that good or bad in your opinion?If you look at the highlight detail on the steps its interesting that ISO 51,200 in SLOG2 looks the same as 6400 in all the other profiles. one stop higher in the other profiles clips the highlights. Whereas 102,400 In SLOG2 is actually still barely holding on.
So there is at least 3 stops difference, if not 4.
So my guess is that "ISO 3200" in SLOG2 is probably close to 0 gain on the sensor itself. Something like ISO 200. With arithmetically boosted lows and mids.
... Not super impressed, to be honest. I mean, yeah, sure the A7S can go to ISO 1 billion, but so what, if it's nothing you'd ever use, meanwhile, the A7S is really no better than other cams at more practically usable ISOs. I'm interested in ISOs I'd actually use, not theoretical ISO BILLION!!!UNO!!!. ....
Is it only me, or others see a great potential in the IQ (overall impression) but yet just ... like something is missing. Like some settings are incorrectly set and whole image is somehow polluted (like to aggressive noise reduction).
Another thing are those harsh edges around highlights - I find them really ugly (2:05 here https://www.youtube.com/watch?v=AvTMpX5NpeM and in other videos as well).
I cannot wait to see some proper tests from pro's...
Not bad but no better than most other HD DSLRs out there.
don't forget any video stating it used <iso3200 is not using slog2 and therefore is operating with seriously reduced DR.
Yes that is true...however I find it really annoying to be forced to use 3200 ISO in daylight if I need to use slog2. Im sure there is a technical reason for that, but I think it will be a pain for many users...
Well it's not quite that simple. In my experience you can (and should to minimize noise) rate/expose SLOG2 1-2 maybe 3 stops over and still get good results depending on how much highlight room you need. If ISO3200 really represents the optimal gain setting, possibly the same setting used at much lower ISOs in other modes, it may not be such a problem. In bright daylight you might just ETTR, exposing closer to ISO400-800 even if the camera says ISO3200.
