A7s sample footage
Thanks for listening. Stuff like this comes with the territory, I guess.
Chris
p.s. I know I'm getting old because I look fat and I don't really care.
hey me too man, fat and old. i really enjoyed watching yours, the building is cool and i think it shows what the sensor is capable of in a richly detailed, high contrast environment like that. as far as feeling more dynamic with the "power-zoom-pan-tilt-rack-focus-sliding", you're absolutely right, but we do what we can with the time we have. you could always add a little push/pull/rotate/slide in post if you feel you're missing it.
as for figuring out your grading preference, my personal recommendation with slog2 is find a pre-made lut you like and start from there (even starting your shoot with that lut in mind). use the lut to get to a good working space, then get creative by adding film looks or creative styles.
that method helps me at least get to a place where i'm starting to feel comfortable.
looking at mine i know a professional colorist would be able to do greater and better things, but we try anyways.
some really cool pieces, thanks for sharing guys.
here are a few clips from a promo i shot a few weeks ago:
slog2/sgamut 4k onto shogun recording dnxhr
Nice. You get some of the best stuff I've seen out of the A7s. I would never know its such a tiny camera with those images.
Casey, thanks for the tips. I just unboxed a Ninja Star last night and shot some s-log2 in Prores HQ and I'm seeing more contrast overall (which is ok) but less dynamic range in the highs coming straight off the sensor. I know you have the Shogun but have you noticed a drop in DR on light sources compared to the internal codec? Anyone?
it's pretty well documented that its a signal issue (going from 0-255 to 16-235) with prores. the information is still all there when you pull it into your coloring software of choice, it just looks more crunched to begin with. a simple fix in premiere is to add a quick color corrector and change your output signal to 16-235
I recorded both internal X-AVC S and external ProresHQ files 1080p at the same time. Exposures at 0, 1 stop and 2 stops over. Then in Sony Vegas 13 I've been playing with turning on and off the convert Studio to Computer 16-235 RGB switch and I see the difference. Prores looks flatter than it was but it still looks like the highlights in the Prores files are a half stop hotter and start to break about a 1/2 stop sooner. I checked the histogram and the Prores files are a little brighter overall too.
Not sure what's going on. I'm used to the internal s-log compression and ETTR about 2 stops. With this ProresHQ I might have take it down a stop. Anyone using Sony Vegas with Prores?
Edit: It's not just me. I found this thread describing the highlight clipping also: http://www.dvxuser.com/V6/showthread.php?332210-A7S-Internal-1080P-vs-Odyssey-7Q-ProRes-1080P
I think I get it now. Sony has a "Levels" plug-in that can correct prores.
Edit: Doing more tests today. internal vs. external s-log. I'm noticing while grading the footage that after I "get where I want to be" (adding film gamma, reducing highlights, etc..) I wind up with about the same image.
So far, the external has better skin tones, slightly better overall color and objects seem to have a more 3D dimensionality to them. Need more tests.
I think it boils down to editing and monitoring in the same color space that the final outcome will be, that way there are no big surprises later on.
An epic collaboration with amazingly talented friends.
Song By: Nick Cave & Warren Ellis
Talent: William Harris III and Samuel Tucker Young
Shot By: Chad Mahadevan and Mike Lloyd
Edited By: Chad Mahadevan
Shot on: Sony A7s w/ 50mm Zeiss 1.5
Graded with FilmConvert
