The NEX-FS 700 4K Camera Announcement & Latest Info!
First, thank you, Frank and the rest of the guys for the excellent coverage and in depth impressions (and input!)
I like everything about this camera on paper, it's absolutely great bang for the buck, but it still has "that" legacy Sony "problem" for me- the only Sony camera that I've used that doesn't have it is the f3 with slog- its that "Sony" look of the picture. I could see what you guys were trying to do with the gradin but it just couldn't mask the "Sony look". Unless they come out with SLog or similar, I just don't like the look of the colors and highlight handling of this.
Actually you can do exactly that. There is a function – besides start trigger and end trigger – that is called half trigger. Haven´t had the time to properly test it thought.
If this is true hi speed 480 and 960fps 1080p at reduced timings I have no more doubts about this camera, just need it to be released to buy it! Thanks Frank, hope you can test it soon!
I've never been unhappy with the images produced by Cinegamma 2 on the fs100. Just love the contrast, the neutral highlights, the pretty roll-off it has.
Lovely curve.
Now that I'm used to c-log it'd be nice to have a log curve though...
The thing I got from the video was the FS100's blown highlights in flesh tones is finally fixed. Good show! Frank, do you recall what gamma curves were used to shoot various scenes?
I also used Cinegamma 2 on my shots as I was using the same picture profile that Frank left me on the camera. I tried all the profiles but Frank's suited my situations best. He really knows what he's doing. I have more specs about my shots used on my blog. http://blog.domisljije.si/2012/04/05/fs700-footage-specs/
Peter: Could you comment on the sharpness and fine film grain structure compared to the C300 or gh2 hacked for example?
cheers.
vincent*
Nice intro video for the fs 700. The images look great. As for the grading...if your a colorist you know you can change it to your hearts content. I'm happy to see the footage didnt fall apart. Its been my experience always to CC and CG sony footage...Pana Im gonna miss your mojo. Good job sony
Can't wait to see more over the next few weeks from the FS700. I like what I have seen so far, it's an improvement over the FS100 which already has a good image.
Don't count Panasonic out of this- They have stuff up their sleeves to come. Panasonic is a
"A" class leader in technology, and I look forward to seeing what they have to offer. NAB should be very interesting. :-)
Pappas
http://PAPPASARTS.WORDPRESS.COM
http://TWITTER.COM/PAPPASARTS
SMPTE 424M is not a signal, its an interface, its also another name for 3G-SDI (like how we call IEEE802.11 WiFi).
3G-SDI/SMPTE 424M sends information in datastreams, they are merely synchronized packets, limited to 2,970Mbps.
Isn't this called (HD-)SDTI?
Or was it 348M?
From the B&H article:
"The 3.5-inch LCD and its detachable viewfinder tube unit carry over from the FS100." Bummer.
Since I've never touched FS100, but I'm really interested in FS700, I'd like to hear experiences with this.
The VF seems heavy and long, so does the lcd's swiwel get loose over time or any or any other problems with it?
Or is the joint sturdy enough?
It's not heavy and it is pretty sturdy, I've had no problems with it
Ok,
thanks for the info.
FS100/700's lcd always looked like it was positioned like EFP/studio VF.
Can it be used in handheld work or is another lcd by the side of cam mic (like they used to be) mandatory?
Toke, I've never even tried using it for handheld- I wouldn't bother. It works for studio/tripod but I cased mine in "the big case" where I store my 3.5mm fisheye, the dedo projection lens and some large mogul base sockets for 1K chinese lanterns. ;)
While waiting for the Kinotek EVF, I've been getting by very well with a 5" Marshall monitor placed in the "right" spot beside the lens. There is a video below that shows how I do it. That video will get a huge update soon because based on the troubles I had attaching my kit gizmos - I'm now manufacturing 4 types of new connector that will streamline "1/4 20 World" .
I've hand held my FS100 a lot. It's no better or worse than any other small form camcorder.
I've never used a side-mounted EVF on mine, but I think others in this forum have. It looks like it'd feel much like an EX3, which is still not an ideal shoulder-mount design.
Or was it 348M?
They all use synchronized packets. HD-SDTI, and 3G-SDI, are interface standards. I think there is some confusion from the interface from the data that is being transported over it.
The data itself is defined by seperate standards, such as SMPTE 296M(720p) & SMPTE 274M(1080p) sampling structures. These sampling structures are what we generically called uncompressed video. This data can be mapped to an interface such as HD-SDI, HD-SDTI, and 3G-SDI. A lot of what was in HD-SDTI has beeen incorporated within 3G-SDI, as it supports the carriage of ancillary data.
SMPTE has standards for uncompressed 2K and 4K video in SMPTE 2048. Which is a sampling structure for uncompressed 2k/4k video up to 4:4:4, but its designed for SMPTE 425M and SMPTE 435M (10Gbps standard) which is more for the future.
With high-speed, high-resolution cameras like the FS700, we're going to see a lot more compression over 3G-SDI. Previously, even the BBC proposed to apply a compression to the HD-SDI signal, compressing a 1080p60 signal by a factor of about 2.5:1 via mezzanine codec, so that it can be mapped into a legacy 1.5Gb/s HD-SDI interface.
