Matthew Bennett
Niiiiiiice!
At first I was being hypercritical of your post thinking- "just buy an FS100 then".
But you're right! Imagine a true modular camera that's completely customizable... I think you're on to something here =]
What's with the warping at 3:30?
No offense to anyone involved but that video was very underwhelming for me, I just couldn't get into it and it didn't wow me at all, maybe it's the 720 or the shot's used, I am not sure.
I made a point in Franks review that should make this camera even better with no hardware changes, just a tweak in the firmware.
High Speed which seems artificially limited for quality in the high modes due to line skipping or compression.
All things being equal regarding frame rates:
960/19sec, 480/10sec, 240/8sec, 120/16sec
Wouldn’t it be possible to get 480frames but only for 4 seconds instead of 8 at full HD with pristine compression? Same goes for the 960 frames if you get only 2 seconds at full HD as an option.
There should be no technical limitation for the buffer and camera to save the same data peaks but in smaller second intervals.
Full HD 1080 Hi speed without compromising quality, just time.
At 2 seconds 960fps it still jumps to 64seconds on playback at 30p.
If we could get this simple fix we could probably get the coveted near 1000fps which makes everything look very very interesting.
At 4 seconds 480fps you still get 64 seconds at 30p regular playback which would be astonishingly good.
