How does it work, the camera can't open the aperture wider, is it locked?
No, the iris is in the lens. The lens itself tells the camera what iris it can go to. f/3.5 is nothing like f/1.8.thanks. So if I get this right, the actual physical iris opening of the camera is with a f3.5 lens as wide as with a f1.8 lens, it just shows in the camera the calculated aperture. Assuming the iris is in the camera, not in the lens.
Please correct me if I`m wrong.
You can get mildly shallow DOF with the f/3.5 lens, but nothing like what you can get out of an f/1.4 lens.OK, so is it possible to get a really shallow DOF with the 18-135 kit lens, since I can´t have a really wide open aperture which I need for shallow DOF?
Around the f3.5/4.0 area in my opinion is a pretty good place to be in terms of DOF. That's usually what I stop down to anyway. But what's nice about a lens with a lower f-stop like a f1.4 or even a 2.8, is that your image is sharper and cleaner at wider aperatures. So if you compare a f1.4 lens to an f3.5 lens and have them both at f3.5, the faster lens will look a lot better.
This is the 2ti with an old Nikon Ai 85mm/1.8. I think I was running at about 2.8...or around there.
These are very compressed stills pulled from the .move file, but you get the idea.
I used a fotodiox (sp?) adapter off of amazon that cost about $20.
Also, keep in mind that I still, even after years, have no real idea of what I'm doing. I just throw on a lens, play with the iso and aperture until it feels right and go for it.
Best,
J.
