Jaime Valles
Well, somebody had to start this thread...
It appears Blackmagic Design has listened to its customers and introduced a new flavor of the BMC:
http://www.blackmagicdesign.com/products/blackmagiccinemacamera/
There's now an EF mount version and a Micro 4/3 version. The m4/3 is a passive mount, meaning you can't control electronic Lumix lenses. This doesn't bother me since all the glass I have for my GH2 is manual anyway. And for filmmaking purposes, you really should be using manual lenses for greater control.
I had given up on the BMC because I didn't want to use only Canon EF lenses, but now that the m4/3 version is due in December, I may just spring for that one.
Blackmagic Design Cinema Camera
Pros:
GH3 (based on current rumors)
Pros:
Whaddayathink?
Pros:
- RAW 12-bit 2.5K
- ProRes 10-bit 1080p
- 13 stops dynamic range
- Great color, filmic highlight rolloff
- Can use practically ANY manual lens with adapters (m4/3, PL, Leica, Nikon, Canon FD)
- HD-SDI monitoring
- Only $3000
- RAW takes up a MASSIVE ammount of HDD space
- No control of electronic Micro 4/3 lenses (Lumix lenses are out)
- Expensive SSDs for recording footage
- Not the best at low light
- No 60p
- No XLR, no phantom power
- No HDMI monitoring
- Bigger & heavier than DSLRs
- Needs external battery to work properly
- No flip-out LCD
Pros:
- Electronic Lumix lenses work great, as do all other types of lenses with proper adapters
- "Wide dynamic range", whatever that means in reality is anyone's guess right now
- 72Mbps All-I recording
- SD cards for recording footage
- 60p in 1080p
- Can take great 16 megapixel still photos
- Flip-out LCD
- HDMI monitoring
- Weather sealed
- Possible XLR attachment
- Possible extended battery grip
- Probably less than $1500
- 8-bit 4:2:0 recording only (most likely)
- Max resolution is 1080p, not 2.5K
- Unknown video quality (don't know yet how filmic the image will be)
- No HD-SDI monitoring
Whaddayathink?
