cpreston
That is interesting. I have never used the Tascam adapter without batteries. But in regards to the Tascam vs the mix pre, while the Tascam attaches to the camera via the hot shoe, how do you mount the mix pre? I own several Sound Devices preamps, the latest being the '888', but they get slung from a shoulder in a carry case, and that results in dangling cable/s that invariably get caught on something.
The MixPre D was designed to be used under a DSLR. It has a 1/4 20 mount on the bottom along with a a 1/4 20 screw on top. It also has a high volume, mic level stereo output that generally is the right level to allow the camera preamps to run at near unity levels. I actually usually use the MixPre on a Noga Arm attached to my tripod, though. I use it for almost all of my interviews because the preamps are nearly transparent, the limiters are fantastic, and the volume LED's are very easy to see.
