Scene Files available for download
About The HVX170 addstp scene file.
It has to increase 1 stop without adding grain. But in my test it's doesn't increase 1 stop. Strange... Experiences?
Greets, Arno
Hi Jan.
I have a question...it might be something I don't understand yet...but when I read the explanations on the website it says that every look repeats and FR will change from
1-default
2-24 fps
3...
4...
5...
6...
But when I look at the text it has 0000500F: 0 ; FRAME RATE: DEFAULT in all 6 positions..
Is this something I have to change myself? it will not be any problem to do so..I just want to undestand well..
Milleto
Greets, Arno
Arno It doesnt actually change your iris setting. I'm no expert but I tried the basic settings of this on my HMC150 and i feel its job is to turn almost everything that doesnt have direct light in a dark scene to black. so what ever is lit seems brighter??? as the setting is just a lowered MP and cineV.
Hello matt s,
Can you tell me where you located the scene files for your hmc 150? Another question-what is the process for using them with the hmc 150? thanks...
I just downloaded the HPX170 files opened the text files and input the settings manually into my 150.There are a few differences and settings we dont have on the 150 but the core scene file settings are the same.
Not as easy as loading them via SD card but I have no idea how to rewrite them to work in that way with the 150 all though Barry G. states it could be done with some patience :)
I couldn't get the Velvet file to work. ( it won't show up in the camera)
And after some looking around. I saw that at the top of each the text files.
It said Ver 1.00-00 AG-HVX200P , and in Velvet it said Ver 1.00-00 AG-HVX200A (punchy had the same promblem, maybe more.)
So just put the A back to a P and everything should be fine.
anyone
anyone
Hi Jan.
1-default
2-24 fps
3...
4...
5...
6...
Milleto
Anyone have an answer?
I'm trying to understand for myself...maybe I just need to change the FR manually myself..
thanks
Milleto
You must be looking at the HPX170 files as the frame rate can be changed on the User buttons. This is in the direction on the 170 download page that the frame rates are all the same because of this feature on the 170.
If you are not looking at the 170 fi8le, please identify which file and camera you are looking at.
Thanks,
Jan
Hi Jan.
thanks for answering. Hope I didn't take to long to get back.
I'm a bit more clear of my question now. I have a HVX200A and downloaded the pana scene files. I uploaded them...if I swicth though F1, F2, F3 and so on...when I go inside the menu they all show, FILM CAM, FRAME RATE 24FPS....AND RECORDING FORMAT 720P/60P
Is that how is suposed to be? or am I doing something wrong? I thought they were suposed to change FR from F1 to f2 to f3..
please explain..
thanks an sorry to bother..
anyone else is welcome to answer ...of course ah
Here is what I get when I download say Punchy. Note that the frame rates do indeen change.
<F1>
SCENE NAME :PUNCHY
00005000: 8 ; DETAIL LEVEL: 0
00005001: 8 ; V DETAIL LEVEL: 0
00005002: 8 ; DETAIL CORING : 0
00005003: 10 ; CHROMA LEVEL: 2
00005004: 6 ; CHROMA PHASE: -2
00005005: 6 ; COLOR TEMP: -2
00005006: 6 ; MASTER PED: -10
00005007: 8 ; A.IRIS LEVEL: 0
00005008: 1 ; NEWS GAMMA: OFF
00005009: 0 ; GAMMA : HD NORM
0000500A: 1 ; KNEE: LOW
0000500B: 0 ; MATRIX: NORM
0000500C: 1 ; SKIN TONE DTL : OFF
0000500D: 0 ; V DETAIL FREQ : THIN
0000500E: 1 ; OPERATION TYPE: FILM CAM
00005010: BE026801 ; SYNCRO SCAN :
<F2>
SCENE NAME :PNCH24
0000500F: 14 ; FRAME RATE: 24 FRAME
<F3>
SCENE NAME :PNCH12
0000500F: 7 ; FRAME RATE: 12 FRAME
<F4>
SCENE NAME :PNCH18
0000500F: 10 ; FRAME RATE: 18 FRAME
<F5>
SCENE NAME :PNCH48
0000500F: 28 ; FRAME RATE: 48 FRAME
<F6>
SCENE NAME :PNCH60
0000500F: 34 ; FRAME RATE: 60 FRAME
From here it very clearly looks as theough the frame rate changes. So which file exactly are you looking at as the 200 files are all supposed to work this way.
Best,
Jan
Hi,
I just asked Mike and he said that when he created ADDSTP he was thinking of it being used primarily for adding more exposure room and with that thinking it seemed that adding frame rates would alter that. Certainly you can add those yourself by loading into the camera making the changes and then saving.
Best,
Jan
Hey I am just confused on the last step of bring the scene files into my HVX200. I go to card functions, I see the scene files, but how do I get the scene files to load onto the camera?
Hi Jan, sorry to keep at it but while punchy is as you showed others are different like this:
HVX200A
Ver 1.00-00
AG-HVX200P
TITLE:ROMANC
<F1>
SCENE NAME :ROMANC
00005003: 1 ; CHROMA LEVEL: -7
00005004: 1 ; CHROMA PHASE: -7
00005005: 1 ; COLOR TEMP: -7
00005006: 13 ; MASTER PED: -3
00005007: 6 ; A.IRIS LEVEL: -2
00005009: 5 ; GAMMA : CINELIKE D
0000500A: 3 ; KNEE: HIGH
0000500B: 3 ; MATRIX: CINE-LIKE
<F2>
SCENE NAME :ROMA24
<F3>
SCENE NAME :ROMA12
<F4>
SCENE NAME :ROMA18
<F5>
SCENE NAME :ROMA48
<F6>
SCENE NAME :ROMA60
Ver 1.00-00
AG-HVX200P
TITLE:DREAM
<F1>
SCENE NAME :DREAM
00005003: 11 ; CHROMA LEVEL: 3
00005005: 15 ; COLOR TEMP: 7
00005006: 18 ; MASTER PED: 2
0000500A: 0 ; KNEE: AUTO
0000500D: 2 ; V DETAIL FREQ : THICK
<F2>
SCENE NAME :DREM24
<F3>
SCENE NAME :DREM12
<F4>
SCENE NAME :DREM18
<F5>
SCENE NAME :DREM48
<F6>
SCENE NAME :DREM60
Ver 1.00-00
AG-HVX200P
TITLE:FILMIC
<F1>
SCENE NAME :FILMIC
00005005: 10 ; COLOR TEMP: 2
00005006: 15 ; MASTER PED: -1
00005009: 4 ; GAMMA : B.PRESS
<F2>
SCENE NAME :FILM24
<F3>
SCENE NAME :FILM12
<F4>
SCENE NAME :FILM18
<F5>
SCENE NAME :FILM48
<F6>
SCENE NAME :FILM60
and so on...
Is this how is suposed to be?
just checking...learning..
thanks and sorry to bother
The filmic one looks like there may be a mistake and to correct it would be fairly simple on your part. Load the file and change your frame rates on the individual scene files and then save it. I am having the guy look through them all and if the frame rates are the only thing that is a problem it is a very minor problem.
Thanks,
Jan
While in Card Functions, Load the scene files, it will display the four that you have on the card. Move your cursor to the one you want to load and then load them again with the confirmation dialog.
Best,
Jan
