Mj:
Its all there in the manual.
You cannot shoot TL in 720 24pN, you need to switch to 720 30p or 60p (assuming you want 720 footage).
Dan
I got some pretty cool results shooting the moon and clouds with the 2fps hack 350 degree shutter. You can shoot 24PN that way too instead of 30p with the time-lapse options. What puredrifting said.
Do you really not recommend time lapses in 24pn?
So are you suggesting all I change is the syncro scan to 350 shutter?
It depends on the look you are going for. If you want straight fast TL traditional look motion with all moving detail visible, you would not want to use a 350D shutter. When you use a 350D shutter, all moving objects will smear and look really blurry, only the still objects will look clear.
We are all calling it a hack because it is 2 fps is not a supported frame rate with the HVX/HPX, but there is a way to fool the camera by editing the scene files to go as low as 2 fps without going into TL mode.
If you want the skinny, go to YouTube and search on HVX200 frame rate hack and there will be a video that will walk you through it step by step, it's simple. I LOVE the frame rate hack but I also shoot plenty of regular TL because it has a totally different look and feel from the frame rate hack, but frame rate hack looks cool with moving objects in the frame like cars at night, planes, etc.
Dan
