brandondull
When I log & transfer footage into final cut pro - it seems when I drag it into the timeline my footage is short in time then the real time I film it at. Any help?
First, pretend like we can't see your editing system from where we are. Which version of FCP? What settings are you using? Which Mac are you using? Which OS? What are your sequence settings?
mac - final cut pro 7 just normal log and transfer
That's a start. What about the other information?
OS version?
Model of Mac? (including processor)
Sequence settings?
Also, are you doing your L&T straight from the card, or from a disk image of the card?
The other thing that comes to mind is that FCP cannot properly L&T, if I'm not mistaken, from a Canon EOS card (or disk image thereof) without the EOS plug-in. Furthermore, the EOS plug-in doesn't yet (technically) support the T2i. There is a hack for the plug-in to work with the T2i, but the plug-in itself won't work in Leopard, only in Snow Leopard.
Your best bet is to use Compressor or MPEG StreamClip to convert the files first, then simply import them into FCP.
imac 27 inch newest version of everything. Sequence settings 1080 HD
Okaaay... still doesn't answer all the questions. Really trying to help you here, and I'm not sure why it's so hard to provide simple, technical details. Believe it or not, this stuff really can matter in troubleshooting.
1) Which 1080p? FCP has several flavors. And are you sure that your L&T setting has the same frame rate as the source footage?
2) Which 27" iMac? Core 2 Duo? i3? i5? i7? And which processor speed?
3) Which version of QuickTime? Are you using the one that FCS3 installed, or have you updated since then?
4) Are you using the EOS-E1 plug-in, or are you just attempting a bare L&T from the SD card?
5) If you're using the EOS-E1 plug-in, have you completed the hack for T2i compatibility?
These are not rhetorical questions. Help us help you.
iMac i7. 4GB Ram. I did the Canon T2i hack. My computer is fine it's the hack that is messing up my footage & I don't know why? It messed up my whole clients project now & I already deleted the footage off the scan disk card.
I don't understand why the canon hack is failing on me? it used to work perfectly! This time i kept the footage but it happened again.
Read around the forum. There are posts of folks having great experiences with the plug-in, and folks having terrible experiences. Go figure.
The only other thing I can think of is to try and trash FCP's prefs; see if that convinces FCP to play nice with the EOS-E1 again. Often, if something that used to work with FCP suddenly does not with no apparent explanation, trashing prefs is the first thing to try.
I HAVE TRIED ALL THIS. I tried opening in a new project & same project as well. Something is wrong with the hack. I don't have the time to read around the forum because I am on a deadline. Thats why I figured I could ask a professional for a quick fix.
Take a deep breath. One, I was not aware that you'd tried trashing prefs as you never mentioned it. You asked for ideas, I gave you some ideas. Sorry they didn't work. Two, the reality is that the hack is just that: a hack that is not actually supported by Canon or by Apple. As such, YMMV, and it's obvious from several reports that sometimes it works and sometimes it does not. It will remain that way until Canon officially provides T2i support for the plug-in.
Now, throughout this thread, I have tried to help. And it seems that I'm getting the flack here for not having the golden solution right off the bat. I understand the frustration of being on a tight deadline and in a technological bind, but projecting that onto the forum isn't going to get an answer. This is also not a problem with a one-size-fits-all solution that we can throw out there without any thought.
One other person has jumped in, and also mentioned that the plug-in is unstable for T2i use. Both of us have suggested using Compressor or MPEG StreamClip, which will get you on your way. Perhaps that's not as efficient, but at least it's stable.
sorry for coming off the wrong way I was replying on my iPhone (now I am on my iMac responding). lol. Will canon ever update it because they are releasing cameras left & right. I feel like they will forget about the T2i. I like compressor I did not like MPEG StreamClip but when I import my footage in compressor its freezing from the things I shot today. Should I reverse the hack or just leave it be?
Use Compressor as a standalone to convert, then launch FCP and import them. I do this with my T2i footage and have no issues. I have found that using Compressor within FCP to do anything is clunky, buggy, and not much fun.
As for Canon updating the plug-in to support the T2i, that's kind of the burning question right now for all of us using the T2i. I wish I could say "yes," but instead I have to wonder about it as you do. No need to reverse the hack, unless you are working with the 7D and/or 5DmkII and having the same issues. Otherwise, just ignore that the plug-in is even there.
