ilauzirika
Boring Senior Member
(once I figure out how to turn on DRS, lol)
it's in the scene file settings in the same page as gamma.
Yeah but it's grayed out even in 720p60.... Not sure what gives.
Darren, In this maze of posts, somewhere, Barry noted that DRS is only available at *some* res/frame rates. I do not remember specifically, but I know 720 was not one of them. I think it was 1080i, which pissed a lot of folks off.
No no, I have the camera in 720 50p (I also tried it in 720 60p) mode and I get it. Try using cine-like gamma and DRS should become available.
drs is only available in 1080 60i i do believe?
The HMC150 and HPX170 have almost identical scene settings. The only real difference is that the 170 has a "frame rate" option and a "operation type" option.I don't know if a HVX200A or a HPV170 will have the same scene settings as a HMC150 or not - likely not. Too bad.
The 170/150 have the same basic scene settings as the 200A, but with more range in the master pedestal and autoiris settings.
the sd card is like a usb stick....the 4 scene files sit on the card. you load 1 at a time into the camera to fill the 6 presets on the dial.Is it possible to save scene files somewhere besides the dial on back? Like the user buttons, or within the menu somewhere? I have not found something like that. Would be so cool if, in the future, we were just able to hook up a USB stick to the camera and load scene files from it into the menu.
