Amadeus5D2
Gh2 less aliasing....AF-100 "clean" hdmi out, messing around people...
GH2:
Af100
Funny isnt it? I was hoping the af100 would at least match resolution to the gh2 but have less aliasing. Confirms my suspicions though.
The stronger optical low pass filter on the AF100 is undoubtedly the culprit. It's robbing the camera of resolution, and now we have proof.
This doesn't surprise me a bit. I've shot with both cameras, and my impression all along has been that the AF100 has typical resolution for a single chip 24P camera, whereas the GH2 has extraordinary resolution, much closer, if not identical to what you'd get with a good 3 chip camera.
On the flip side, the GH2 has some chroma issues which are probably the result of it's weaker OPLF. But since the human eye is more sensitive to luminance than chrominance, the overall effect favors the GH2.
In an ideal world, it would be great if digital cameras had two OPLF's which the user could select from.
But I doubt that's going to happen, so I hope camera manufactures take this as a stimulus to rethink their formulas for optical low pass filters, using the GH2 as an example of what can be achieved.
Wouldn't a stronger OPLF equal less moire?
Apparently with the right script in AVSynth you can also get this on the GH-2 (it's not perfect but it's definitely an option). And, if you see some of the comparisons, as sharp as the AVCHD on the GH-2 is....the HDMI is even sharper (yes...including the low light areas).Gh2 less aliasing....AF-100 "clean" hdmi out, messing aro und people...
The performance of the AF-100 is very dependent on the lens used and the camera settings, so without seeing a full breakdown on the lens and the setting used during shooting, I won't trust the results of this test.
this is Fact - the low-pass-filter (AF100) is the problem . . .
well gad damn... My af100 test chart looks pretty much the same as the german shoot. I'm pretty annoyed to say the least.
bottomline gh2 rocks.In the end....none of this will matter.
