Cyril-from-France
No 4k120fps to 4k prores ... Not usable but interesting .... but 2K/240 doesn't work at all (for me)
Are you applying the matching LUT in post in a program like Resolve or Premiere? The LUTs in the Odyssey show a preview of what the correction would look like later. The matching LUT can be downloaded from our website to then be applied in post so that you see exactly what you saw on the Odyssey OLED. There are instructional videos on our website to show how to apply these LUTs in post.
I think you should be in contact with our support desk for detailed assistance. I'll go over this in a short, general way. For greater detail you can consult the various white papers and videos on our website.
Set your camera to S-Log2 with no additional gain applied so that it is at 2000ISO. Make sure to set your white balance correctly.
Set the LUT in the Odyssey7Q+ to the S-Log 2 two stope compensation LUT (SONY EE SL2 L709A-2). Adjust your exposure based on this LUT. Many people do this in different ways but if you are viewing the LUT it is WYSIWYG. I tend to suggest watching that highlights don't clip on the waveform and shadow areas don't fall too far into the darkness, and that generally the stuff you want to see as bright "proper" exposure be somewhere between 60-80 IRE. That's a nice, fat signal with some highlight range retained.
The LUT function on the Odyssey is for monitoring only and does not alter the recorded signal. When you import the footage into a program such as Resolve or Premiere, it will likely look quite overexposed. That's because you were viewing it on the Odyssey with a LUT that made everything appear two stops darker. To get it to look the same you need to use a matching LUT. These LUTs can be downloaded from our website. If you cannot find the correct ones (FS7 v. FS700) then please contact our support desk for assistance. The LUTs will download as standard Image Cube file format and can be easily loaded into your post program (consult our white papers and videos). Apply the LUT and you should see exactly what you saw on set on the Odyssey.
If the image is still noisy, there are two factors. One you may still be exposing a bit dark, and I suggest you experiment with different exposure levels. And two, this recording path introduces no noise reduction unlike the internal HD recording in the camera. You may simply need to add in a small amount of noise reduction through a plug-in software that will smooth out the image a bit. A few options have been mentioned on DVXuser as popular options in the past.
