Two vans.some one is shooting from outside the van!
Sorry but i couldn't find out the link for pdf file of cam?I want to check if this camera both PAL&NTSC?Is it?
I wonder if Panasonic will give a free 32GB card if you go with the HPX300. That way, it will definitely make it worth the buy than the $8k JVC HM700.
Photos of, taken with the D90.Barry are these stills from the hpx 300 or fotos of the hpx300 ?
Three. Two on the back, one in the front.Are there 2 or 4 xlr audio inputs?
No, it's still 16-bit 48KHz.Being a 10 bit camera has the audio been able to improve (not that it was ever bad) from 16 bit 48k to a higher bit rate or sample rate?
? Not in the same league. The HM700 is a mini-sized unit using (presumably) 960x540 chips and recording to 8-bit MPEG-2. The HPX300 is full-sized using 1920x1080 chips recording to 10-bit AVC-Intra. Totally different.I wonder if Panasonic will give a free 32GB card if you go with the HPX300. That way, it will definitely make it worth the buy than the $8k JVC HM700.
