shaocaholica
use the lens as a variable prime, see my earlier post
I think the term "variable prime" is a bit confusing. Its practically an oxymoron:happy:. Why not just say don't zoom while shooting?
I do NOT remember this happening on my old zooms, but there was no computer in them or my cameras. Is this a function of the new technology? Or is my memory just faulty. It has been a while...
Lens manufacturers such as ARRI Media[5], ISCO Precision Optics[6], Schneider[7], Carl Zeiss AG[8], Canon[9] and others still make variable focal length cine and video lenses regularly catalogued as variable primes. A variable prime is sometimes distinguished from a "true zoom" in that the latter maintains focus as the focal length is varied.
Ok thanks. It seems the AF version is a little softer, has some CA and introduces that colored moire that we've been seeing. Funny thing is the IS version looks sharper, more contrasty and has none of that moire.
Wait a minute...if you're shooting at 24, 35, and 50 on an 18-55 using a 7D/T2i, your field of view crop factor (1.6x) is giving you 38.4, 56, and 80. Are those the focal lengths you were referring to as often used in film making?So you have three prime focal lengths that are often used in film making (24mm, 35mm, 50mm) all with more than decent quality and a perfectly
workable f5.6 aperture on all three lengths and all in the one lens. The zoom is built for 18-55 so if you stay at 24, 35 and 50 you are never shooting at its widest (avoiding barrel distorion) or longest (avoiding pincushion effect).
Canon EF-S 18-55mm 1:3.5-5.6 IS review
http://www.dpreview.com/lensreviews/canon_18-55_3p5-5p6_is_c16/
"Headline features
- 29-88mm equivalent focal length range
- Optical image stabilisation – 4 stops
- EF-S mount for Canon APS-C dSLRS only"
That what I was thinking. Canon's EF-S 15-85mm IS would cover all three. My knowledge of common film making lenses and their lengths is rather limited.But to get to what J Davis' meant one would need approximately:
15mm - 22mm - 32mm sized lens. The kit lens would cover the last two.
Um…If I’m not mistaken, I believe those kit lens were made for this sized sensor. So 18mm will be 18mm. This lens should not fit on a 5Dll.
Then again I've been wrong many times before.
It's 18mm cropped 1.6x to 29mm full frame equivelant view, IE your 18mm on the 7D will have the field of view of a 29mm on the 5D, but the other properties of an 18mm (distortion, DOF, etc.)
If the lens is designed for cropped sensors it simply means the image circle isn't large enough to fill the 5D's sensor...but if you put it on the 5D the parts that you did see would be the same as if you put a full frame 18mm lens there.
Thanks Ben...I understand this. But the term crop is throwing me off.
When using a 7D/T2i we are actually shooting on a “standard Hollywood 35mm” sized (roughly) movie camera sensor (not full frame for stills), so, based on the sizes given by Mr. Davis, we are not going for the full frame 24mm, 35mm, 50mm equivalent…
I guess an example would be this: Someone wants to approximate the size of a typical Hollywood 24mm camera with their 7D/T2 using the kit 18-55mm kit lens. Well, since the sensor of the 7D/T2i is almost exactly the size of those standard 35mm movie cameras…then to get its 18mm equivalent (with this lens) just shoot at….18mm. This was the reason for my first response about the kit lens. 18mm…is 18mm. 24mm is 24…etc. for filmmaking we are not talking about Full Frame equivalents. This is why I don’t like the term “crop factor.” In what we are all doing here (film making)…that doesn’t make any sense. If we are strictly talking photography….then it would be correct to use “crop factor.” IMO
Actually 35mm motion picture film has a 1.3x crop factor vs 35mm full frame photography. The 7D has a 1.6x crop factor.
