GH4 GH5 specs ?
Has everyone seen the camera specs for the just announced DJI Inspire 2 X5s camera? Link here: http://www.dji.com/zenmuse-x5s If that thing had a stand alone camera it would put a serious hurting on the new GH5. The camera mount with camera/no lens is $1400. But, in all fairness you have to add the $900 SSD drives to that price for recording raw.
I guess that there is absolutely no chance in hell that Panasonic is going to give is raw recording capabilities with the GH5.
Wayne Mann
www.HeliCamHighDefmedia.com
Hollywood-grade, but no hollywood frame rates? Where is 24p or even the industry standard 23.976? Odd.
It's likely the same sensor - since that is the sole 20 MPX MFT sensor that Sony makes - that's inside Olympus OMD EMI MKII, Panasonic GH5, DVX200 and GX8. Both Panasonic and Olympus promise different tweaks but no one knows how much tweaking actually takes place.
It's highly unlikely GH5 will record Raw to SSD's.
Now, had this been an AF-100 replacement ...
I agree. But how freakin' awesome would it be if the GH5 also had an M.2 slot for 4K CinemaDNG recording? The form factor certainly wouldn't be the barrier to that design, as it would with 2.5" SSDs.
There's a considerable variety of mobile and embedded memory tech that could support a compressed Raw in a $2,000 camera. I think it's all going to the UFS 2.0 platform for the lower end and for straight SSD's (such as X-point) on the pro size cameras. Some of the higher end external recorders and pro cameras can also contain multiple drives suitable for recording an uncompressed Raw. The top tier mobile phones cost $200-$250 to manufacture and already have the latest memory modules. The Chinese made drones feature essentially all off-the-shelf camera components - Sony's MFT sensor with an MFT mount that can take Olympus and Panasonic lenses, etc. It'd be interesting if someone can hack that DJI drone-camera combo and make it into a stand-alone 4K Raw camera. Currently, as I read the posters comments, the SSD is inside the drone body.
...I'm dreaming, but a GH5 "Cine" grip that recorded RAW to standard M.2 SSD drives would be killer. Even if it was priced as a $1,500+ add-on, I could still see it selling really well. ( just don't build it like the infamous YAGH device )
The sensor should shoot for more stops...around 14 or 15.
Technically, it can be done by taking multiple exposures, a la 5D MKIV (1080P only) and the Red cameras. As cameras get higher and higher frame rates, the difference between the frames will be tiny anyway, so blending will be even easier (although, it probably better done in post).
With RED's HDRx system the second "highlight" exposure is shorter relative to the dynamic range increase. So if you are shooting 24fps at 1/48 second for the "normal" exposure, and you want to increase the dynamic range by 4 F-stops, then the second "highlight" exposure is 1/48 x 1/16 = 1/768 second. The difference between images would be minimal, but the second exposure might be a lot sharper. ( I've heard of people softening the second exposure in post to get it to match the first exposure better, before they are blended to create the HDR image )
I just want to know if it's softer then the GH4.
The GH4 is so rough and grizzled on the outside. Feels like my wife after she shaves.
I hope the GH5 is a little silkier to the touch.
Ah, thanks. I wasn't sure how the Red is doing it but it makes a lot of sense (now that I have been explained it).
I'd rather it was done properly, with a better sensor.
The current era HDR TV's and monitors will top out at 12 stops and even that is probably too jarring to people's eyes. basically, in terms of both resolution and the dynamic range, the human eye limit has been reached (with the exception of some commercial applications). And, for scripted narratives, 24p seems to be much preferred over 48p or above.
