GH2 100Mbps Flow Motion v1.11 Failsafe Patch with HBR 25p & 50p support
Released below is a minor revision to Flow Motion v1.11, tuned and tested for failsafe operation in all PAL video modes, including ETC zoom mode. In addition, it also supports failsafe operation all NTSC modes except for ETC mode in HBR 30p and FSH 60i.
In short, this is the 100Mbps GH2 version of my Reliable In-Camera Playback Patch.
Congratulations once again to Vitaliy Kiselev for cracking Panasonic's recent firmware v1.1 update for the GH2! PTool v3.64 now provides support not only for the new HBR 1080p25 and 1080p30 video modes, but for custom Quantizer Scaling Tables as well. Custom tables enable patch developers to tailor the compression properties and image quality of each of the AVCHD 1080p, 1080i, and 720p video resolutions. In addition, cbrandin's invaluable Stream Parser and Scaling Table development tools have made it possible to quickly take advantage of these new PTool features, providing an unprecedented level of control over the GH2's video recording functions. Combined with the capabilities of Panasonic's v1.1 firmware, this has resulted in numerous improvements to the reliability and motion picture quality of Flow Motion v1.1. Here is a concise list of its features and specifications:
As with any complex video camera, there are a number of considerations and limitations to bear in mind:
Original Flow Motion v1.11 sample videos may be downloaded from the following links:
Looks even better in the original MTS clip, downloadable from Vimeo!
GH2 100Mbps Flow Motion v1.11 downloadable INI patch file, for use with PTool v3.64 :
- 100Mbps AVCHD in 24H 1080p24 and SH 720p50/60 at 8-10 keyframes/sec.
- 75Mbps AVCHD in HBR 1080p25/30 and FSH 1080i50/60 at 8-10 keyframes/sec.
- 50Mbps AVCHD in 24L 1080p24, FH 1080i50/60, and H 720p50/60 video modes
- 100Mbps MJPEG 1080p Patch maintains high bitrates regardless of light levels.
- Full support for all NTSC and PAL video modes.
- In-camera playback of all AVCHD video files. (MJPEG HD videos not playable in-camera.)
- 4GB AVCHD file-spanning in all video modes with 95MB/sec UHS-1 SD cards.
- File-spanning in 24L, FH, and H modes supported on all Class 10 SD cards.
- ETC zoom mode with failsafe operation in all modes except NTSC HBR 30p and FSH 60i.
- 80% Slo-mo 24H video mode with ETC and file spanning in 24L mode.
- Combines optimal I-frame size with compact, 3-frame GOP file size (GOP-6 in 720p modes).
- Customized Scaling Tables produce P and B-frames that match I-frame quality.
- Listed bitrates are the maximum seen in practice, filming well-lit, sharply-focused, highly detailed scenes. Average shots will produce average bitrates. In low-light conditions, I recommend trying MJPEG HD 1080p30 mode for its ability to maintain high bitrates in near dark conditions.
- If shutter speed is set longer than the frame rate (e.g. slower than 1/60 at 60p), low-quality video files may be produced. High shutter speeds will reduce motion blur, which may force the encoder to operate at higher bitrates.
- ETC zoom mode increases the bitrate and puts significant stress on the encoder. With Flow Motion v1.11, Failsafe ETC mode is now supported in all PAL video modes, and in all NTSC video modes except HBR 30p and FSH 60i modes. ETC actually does work in all modes, but I've found that with Panasonic distortion-correction lenses, it's not 100% failsafe in HBR and FSH modes under the most extreme conditions. With manual-focus vintage lenses, it has so far proven to be failsafe in all modes.
- Flow Motion v1.1 has been tested extensively at ISO 3200. It is not tuned to work reliably with PTool's extended ISO patch, but higher ISO can be used in underexposed, low-light conditions.
- Panasonic Lumix distortion-correction lenses are now fully supported in Flow Motion v1.11. For smoothest results, I recommend using these lenses with a mild softening filter to reduce their over-sharpened edge artifacts.
- The 24L, FH, and H video modes make use of a special "Trick Mode" that ensures reliable file-spanning at 50Mbps. It does this by setting the video file's transport stream bitrate to a much lower level than the video stream's bitrate. These files play back correctly in video editors with no need for post-processing. However, MediaInfo and Windows will report incorrect duration and bitrate for these files when examined on the desktop.
- I recommend using the camera to format your SD card at the start of each shoot, to guard against SD card memory fragmentation.
- This patch requires Panasonic GH2 firmware v1.1 and PTool v3.64d. For download, installation, and usage of these components, see the following FAQ: http://www.personal-view.com/faqs/ptool/ptool-faq
