Vitaliy Kiselev
Carbonite Member
Links?
We have first page for links and actual info. It is updated.
Links?
I've sent a donation. I urge everyone to do the same right now. I was in charge of the HV firmware hack over on HV20.com for a long time, and progress there was/is very slow.
I was waiting for a global-shutter GH2 (if the rumours are true), but if the hack manages to enable video out during recording (even just composite), higher bitrate and defeats AGC I might grab a couple.
I want them for stereo (3D) shooting, so being able to sync exposure parameters, white balance & focus between two cams would also be a huge deal.
As far as I remember camera had been bricked during attempts to dump firmware![]()
I looked at this project closely some time ago .
It is very interesting to look at disassembled SD100, TM300 and TM700.
PAL switchability is very useful thing.
I really don't know how it is possible to do.
May be thread monitoring USB . But it'll be real hard, as only Canon have full PTP commands engine (this is btw real reason of such good progress on Canon cameras).
Cameras can also drift with time.
PM me your email address & I'll ask our hacker (jollyrogerxp) to contact you.
A lot of people said that PAL/NTSC is hardware- specific - that might have been true in the past but it's probably all in the firmware now.
I read somewhere that Panasonic do have comprehensive USB control, but they reserve it for their service engineers? Obviously this is advanced stuff, when the firmware is better understood, other programmers can try it (I'm a C++ programmer myself).
Regarding PAL/NTSC switch and other regional switches.
I have the service manual which says that when the main PCB is replaced it pops-up a question to enter the region code.
This code drives the supported languages as well as the supported TV standard PAL or NTSC.
After the option was selected the pop-up may not appear again, according to the manual.
We could try to place it on some rarely used parameter, like VieraLink![]()
If he don't have Panasonic cameras (like TM300) I don't know how he might help![]()
How much I'd like it to work, right now it does not. I have put it on a formatted SD card and still get No Valid Picture To Play. I am using the AC adapter. Could this be because I tried your firmware update test before? Did anyone else succeed in upgrading from 1.21? (Or is it 1.22?)
downloaded, patched correctly 50p-60p -> 24p using makefps, and installed in gh1, it works!, now the camera shows firmware version 1.2
but unfortunately it does nothing, just recorded some videos in every mode and mud is still everywhere.
mud test is not very technical, but checking the video gives the same results:
resolution : 1280x720
framerate : 59.94
profile:level : High:4.0
bitrate real max : 16 051 020
avg (I) : 142 233
avg (P) : 27 928
P frames still get the muddy 27k per frame.
It is to be expected.
And it could have saved me some time if I knew that it actually shoots at 59,94 as I already found some references related to this.
Check if available shutter speeds changed. As something related with FPS in AVCHD must change.
