GH1 firmware research volunteers required
But we need to modify patcher, so it can produce any version number (otherwise next experiments will be impossible).
Also some time is required to understand this framerate stuff and make few experimental patches.
P.S. Again thanks all guys, especially ones who only read this thread and donated even if not much. Thanks!
i am new here and glad that i read this thread from day one, and now i keep my eye on this thread all day long.
awesome! Brilliant !!! keep going, tester.
  • PayPal balance: $236.76 USD
if you want to be on a list of donors just PM me your "handle" with your email address so I can match up what you've sent. I won't divulge any amount unless you want to. gotta say i'm impressed so far with the progress of tester13 and the amount of donations involved. this could be very beneficial to everyone.
From firmware code it looks that GH1 PAL record 1080p25 in 50i wrapper (or this is native 25p)?
I believe that if we change 29,97 *2 to to 23,97*2 for NTSC it could be easear to remove for 24p guys. No?
I'm curious, if firmware upgrading now works, how hard is it to remove the PAL 30 minute limit? It is a big nuisance for me when doing interview work. I'm thinking it would just be a replacement of the code from the NTSC version, considering it doesn't have that limit?
All necassary places are located and marked, changes are known. But it is not that easy.
We must start by patching only limit, not region check.
As region check is used in many many things, like composite output setting, framerates, etc.
For starters I must make ptool with normal user interface that allow you to select any amount of hacks in checkboxed list and set firmware version by just spib box. And this require time.
But we need good tools first.
I see. I wish I was more knowledgeable in coding to help you out, alas I only know some limited C++.
Patching the test instructions.
You can replace the compare instructions with NOP (no operation) instructions, or reroute the addresses to the desired path.
Good luck.
If I remeber correctly, when some of the working first GH1 prototypes where shown at some photography show- a fellow brought an SD card and shot a few clips then put the raw clips up on the net. I specifically remember downloading the raw clips and that they were 1080 24p native with no pulldown, and the footage hadnt been modified in anyway by the guy- just uploaded from the sd card.
My guess is that the gh1 was originaly 1080/24p native avchd, then panasonic decided to add a pull down to give more compatibility with consumers video editing programs and televisions before its release.
So its not hard for me beleive that a native 24p hack should be quite doable and possibly even easier than it seems. Anyway, Thanks for your efforts.
the composite(HDMI) output is switchable between PAL and NTSC in menu setting without region check, for your information.
No, they are not fractional.
They are just multipled by 100 :-)
Notice that only NTSC model have two different frame rates set.
All else is the same, and must be native.
so VP_Framerate_3 seems to be the real framerate and VP_Framerate_4 the file framerate.
1080 mode adds pulldown interlacing frames so there should be an extra step before saving. 720p mode seems to the perfect to experiment, would like to know what happens changing only the file framerate.
Can you tell me if there is any future possibility of changing the frame size (as long as datarate is kept within current limits)? Since experimenting with some Sumix camera heads a couple of years ago, I really like being able to set a CinemaScope frame for video! 2K CinemaScope is "only" 2048 x 858, which is a smaller pixel area than full HD (1920 x 1080). The ability to shoot native 'scope would be a unique capability for many people. From your understanding of the firmware so far, could you definitely rule this out -- so I won't keep wondering about it!
Thanks.
It can be possible. But we don't know that is hardcoded and that is not.
