GH1 firmware research volunteers required
Hello'
When I turn on camera and push "Play mode" button I have same text on the display "NO VALID PICTURE TO PLAY". Yes is same like empty SD card.
PS: My Panasonic GH1 have 1.21 version of firmware.
Regards
NURBS
It is simple.
Initially it started as small patch for TZ5 to change very bad 8000KHz/8bit sound encoding in HD movies my family use (not for films, of course :-) )
After I realized that GH1 is very good capable camera with few clearly seen flaws and firmware format was almost the same, processor commands are the same. (and digest protection is the same )
So , GH1 project started.
hmm.ok. you lost me at "Initially", but i get it. conversation is not your thing. good luck.
@Chris Light: aint it obvious? it's a good chance for him to get an GH1 without spending money in the process ;) to be frank, he still deserves it, either by the time spend on the FW hack or by the genius involved (even if he spends almost no time on the hack).
@tester13: are descriptions of tried/failed FW updates in text style really of any help? wouldn't it make more sense to get the next best thing to an test body: short videos (even very small & low res crappy ones captured with an phone), at least until enough donations get in to get you a GH1.
It is not the case here :-) As it is quite strange approach to get GH1, don't you think? I did not start this thread asking for body, instead I asked GH1 owners for help, and use their GH1.
Text descriptions are fine, we don't need any videos.
But if you have time, do it.
K.S for what it`s worth i dont think Tester13 has a motive to aquire a free GH1 by engineering these solutions :)
And Tester will you keep us posted as to how close we are to raising the amount needed for a test body?
I donated. If he gets a camera out of it, that's great. If we get firmware out of it, that's even better. If he has a camera to actually work with, that would make the likelyhood of working firmware even more likely IMHO.
Hmmm...that explains why it has to do LCD and composite output at the same time, why it can't do viewfinder and composite output....interesting.
I don't think this is the case, as on my Sony the composite output works fine during video recording. If they have an issue with supporting both they could switch off the LCD when the composite is in use.
Different hardware have different specifications.
Main CPU for this LSI chips is generally quite slow.
All other parts are dedicated hardware and if it was not designed having composite working with LCD and simultaneous recording it won't happen.
Camera read sensor (with line skipping) ->store this at RAM -> make debayering->store resulted image in RAM->scale image to viewfinder or LCD size, scale same image to composite size, and finally encode this image and store resulted data on SD card. Storage is in separate thread, compression and scaling are cruicial tasks, and if it can't scale to two different images and encode whole image at same time it just means that it can't. But as soon as encoding is not performed it can do this on time.
In fact it looks that you just went too fast. :-(
As we now know actual upgrade was not necessary to make jet. :-)
As I understand, if using make_fps.bat you could have 24fps camera with 99% probability :-)
And it is not possible to downgrade, as far as I can understand?
It looks like Panasonic allows for downgrades of firmware.
I tried this with my LX3 and it works. I could revert form 1.3 to 1.2.
So it looks like the camera will allow any update that is different from the current one.
Good luck and thanks for the effort.
Tally so far is $113.75. One person donated a whopping $50.00!
Also wanted to advise, that if within 60days everything goes to poop, I have the option to refund all the donations.
$113.75 `s not to bad!..i just added a bit to that and will add a bit more when i`ve got some more to spare..How much do we need to raise by the way?
Thanks. It looks that it checks only few bytes, then load whole firmware into memory, check digest and you get this error.
We also want someone with V1.21 to try it, as it seems that their version do not see update image, so we didn't change some version specific constants.
Next time, post photos of whole process, including progress bar and resulting message.
Timing is also interesting.
tester13, the process is exactly this:
http://panasonic.jp/support/global/cs/dsc/download/fts/step_bg.html
when the green progress bar is about 20%, like on <Fig.6 Version up on Going.> , the process interrupts and shows a message "turn the camera off and then on again". It takes only 5 seconds.
for testers: the battery must be fully charged or the "no valid image" message will appear when trying to load the new firmware.
