It's the miraculous ability to predict the future. Broadcast and DVD/Blu-ray encoders have virtually unlimited resources available that enable them to scan through the unencoded video stream with multiple passes. This gives them the power to precalculate bitrate allocations and track down optimal motion vectors before encoding each video frame. In contrast, the real-time video capture codec in a camcorder is constrained to using the subset of encoding tools that are guaranteed to produce valid video frames within the limited time slice budgeted for encoding each GOP. This handicap results in lower image quality and less efficient encoding than is theoretically attainable.One thing I don't understand though is how TV shows can do a complex water scene like this at 18 mb/sec or less MPG2?
One thing I don't understand though is how TV shows can do a complex water scene like this at 18 mb/sec or less MPG2? My over the air actually doesn't look half bad.
Yes, please post the exact settings that you use so that I can try on my GH1. Thank you!Like I said I have about a 99% reliability rate using transcend class 10 cards and 100% with sandisk extreme but that cards just too expensive for me I can deal with a write error every thousands takes or so. What do you want me to actual post the 133 hacked file?
The insidious problem with using Native 24p on the GH1 is that the recorded videos may contain corrupted frames that appear to play back without error. What typically occurs is that one or more empty frames are recorded just before a key frame. When the video is examined frame-by-frame in an editor, it can be seen to pause briefly for the duration of any empty frames it contains. A detailed discussion of this malfunction can be found here:...I have about a 99% reliability rate using transcend class 10 cards and 100% with sandisk extreme but that cards just too expensive for me I can deal with a write error every thousands takes or so.
Blackout, you can open your .ini file in notebook and cut and paste it into your browser, or you can upload the ini file as an attachment.Yes, please post the exact settings that you use so that I can try on my GH1. Thank you!
... It reminds me of the BS that people used to say about putting a purple marker around the DVDs or whatever to get a better high quality result. ...
You mean I'm _not_ supposed to do the purple marker thing around the edge of the front glass of all my camera lenses? Whoops!![]()
By going through this thread it looks like Blackout achived some good exposure for his website, free advertisment. I even went to check his website out and laugh at some of his funny pranks, that he did accomplish for sure.
I don't know what you're talking about. No one reads this thread but the utmost pixel peeping squeek squeeker squeekum hacking geeks. :2vrolijk_08:
As to the corruption problem, it has not been an issue for me so far. I'll post a copy of my hack settings soon after I take my mid night nappy nap.
- Blackout
Needless to say she is gone and the romance with the GH1.3 still continues....
but who can you talk to when you're lonely? (instructions manual?)![]()
