Edit: Just saw you were in 5.1.4. Hm...if the above doesn't work, then try this:
Final Cut Pro > Audio/Video settings
Sequence Preset: HDV 1080p24
Capture Preset: HDV
Device Control Preset: HDV Firewire
Have you all tried changing the [Playback STD] setting within the A1 menu? See pages 95 and 109 of the A1 manual.
I found that if it's set to "Auto" FCP didn't recognize the A1. Changing it to HDV did the trick.
My Playback STD is greyed out, as well as the down convert option... any ideas why?
I had the same problem with my ai with pp. I really dont know why Cannon continues with their proprietary 24f crap. It would make thins alot easier if they switched over to true 24p. My 2 cents.
This really isn't relevant, accurate, or helpful. 24F=24P.
24f and 24p yield similar results through different methods. 24p is proprietary and something canon didn't want to pay for.
The relevance is that if canon used 24p instead one wouldn't be having a lot of these fcp problems.
I don't get it it either.
I have been importing footage fine off of my HV20 and A1 with the easy setup in Final Cut 6.0.1. (HDV, HDV 1080p24, 23.98)
Then out of the blue it won't recognize either camera. Down convert is off, STD is HDV...
I was able to fix this by reopening FCP...but not anymore, also imovie does not see the cameras either....
Any ideas...?
