nyvz
Margin for experience, I'm sure. 32-45ish sounds fine to me, and about right. Did Samuel post a measure for how many stops over Middle Grey A7S SLOG2 XAVC S might have?
My understanding is slog2 generally gives about 7stops over, 7stops under middle grey. That seems to be how it is on my fs700 at least. But I would overexpose up 0-2 stops to minimize noise, which gives more like 5-7 stops. By comparison, most similar cameras seem to be designed for about 4-5.5 stops (c300 clog, red mx redgamma4, sony fs700 cinegammas, bmcc). I'll test later today after my camera arrives though.
Looks pretty soft, noisy, aliasing and moire in some shots. Not that impressive....
Yeah that's what I'd expect given the use of gamma curves that severly limit DR. Actually it looks surprisingly good for non-slog2 footage I think compared to a lot of the footage I've seen out there using random unmanaged gamma curves. Keep in mind 60p seems to be not using the full sensor, so it is likely to have more noise and aliasing than 24 or 30p. Basically I can tell you people will test the camera with various gammas, but in a few weeks it will be far more clear to everyone how important it is to shoot slog2 or, if you really have to, rec709 800%. The top couple stops of DR are by far the most important as they are the cleanest stops the camera has, so to throw them out by using any other gamma is pretty crippling unless you want that blown highlights, noisy shadows look.
