ReelWorksMedia
Haha...you said PP test.
Thanks for posting that L1N3ARX
ReelWorksMedia, that review had me feeling good...until he did the side by side with the Lumix GH4. Then I was like, s*%t, it looks fantastic and records 4K internally, and outputs 10bit.![]()
This looks promising for DR:
https://www.youtube.com/watch?v=9O29EMHiEhA
While it does look like slog2 has more noise in shadows it has a lot better DR in highlights. I would expose the slog to the right and then bring the shadows down a bit in post and voila, you have a really nice image![]()
There's just something that's not quite right about the GH4's color science that often makes things look unnatural - particularly grass, foliage and skintones - too much saturation in shadow areas, perhaps? ...
The image from the A7S however, looks to me to have a significantly more "natural" feel to it.
T
Some of the GH4 shots looked great. But some of them looked too plastic! There's just something that's not quite right about the GH4's color science that often makes things look unnatural - particularly grass, foliage and skintones - too much saturation in shadow areas, perhaps? Too much smoothing of lower-contrast areas, perhaps? I don't know what it is exactly, but I do know that 10bit can't help!
I think it would be possible for Sony to implement a way to do the S-Log2 grading inside the camera before the 8 bit compression. Sony could enable different grading levels to shadows/midtones/highlights for the user to chose and turn the S-Log2 image into a graded image inside the camera, this way there would be no need of post production grading, much faster workflow and would avoid gradient banding. I think this is simple to do, just enable a menu function with some grading algorithms or lut curves. Also it would be interesting to allow the user to load custom grading presets to the camera.
i think it would be possible for sony to implement a way to do the s-log2 grading inside the camera before the 8 bit compression. Sony could enable different grading levels to shadows/midtones/highlights for the user to chose and turn the s-log2 image into a graded image inside the camera, this way there would be no need of post production grading, much faster workflow and would avoid gradient banding. I think this is simple to do, just enable a menu function with some grading algorithms or lut curves. Also it would be interesting to allow the user to load custom grading presets to the camera.
.picture profile parameters: Black level, gamma (movie, still, cine 1-4, itu709, itu709 [800%], s-log2), black gamma, knee, color mode, color level, color phase, color depth, detail, copy, and reset.
^ should be enough to fight the 8-bit curse (my plan was to increase contrast a bit so I get better gradation in the midtones at the expense of highlights and shadows, as long as they don't clip any sooner; all these controls should help to get an even better result)
Please post resulting profiles
If I find anything worth sharing, there will be a Flaat for a7s, just as there was for 5N, even if it's not an actual profile, but a series of settings
Now:
I've been playing with the raw files from the Arizona falls video:
https://twitter.com/wamaddox/status/482520903755239424
Some comments:
* Nothing goes above 85% IRE, except from some speculars in the water. I would have thrown two or three stops more light into the sensor. For me, in daylight, slog2 is ISO 400-800, definitely not ISO 3200.
* The image only fills a very small part of the IRE range. There's A LOT of range not being used in these clips, often close to 50%. That's a sign of great DR: there could be much brighter and much darker stuff in the frame and it wouldn't clip.
* I've been trying to break the codec. I added loads of MB Mojo, loads of contrast, etc. For anything reasonable, the codec holds. When it breaks, it is because of ugly noise (I can get banding in the sky, but noise is an issue before banding is).
* I was afraid I might have to go Premiere CC, but CS5 loads the files without issues.
That's my plan: to throw more light into the sensor, overexposing with respect to Sony's ISO3200 rating, because there's plenty of room in the highlights and it will make shadows cleaner, while requiring less ND.If the Arizona falls clips could have been exposed brighter, I would think that could have reduced the noise in the shadows. Thereby making the clips even more gradable. Right?
