This is what reflectors are for.
Would a 1.2 hmi do the trick?
I'm planning to shoot outside on an overcast day in the forest/woods. So that's a lot of light cut out from the sun.
I want to punch the subject out of the background by making them brighter than the background.
So I was thinking of adding a ~300w china ball as a toplight. I could even do 2 china balls and mask the top and sides with a black blanket.
I'm just wondering whether this 300w will do anything before I go out and test it.
I'll be running power off a car battery being charged by a running car. What's the max amount of watts I can pull from a car battery in case I need more light?
Ref shot:
I happen to know for example that my camera needs 42 fc to expose middle gray at f4. That means if I color correct the ARRI 1k and even lose a stop, I'm still getting 57.5 footcandles on my subject, or like I said around f4. That's 20 feet from my subject and on a medium focus setting. If you make it more spot or move the light closer you're easily going to be able to get 1 stop over your ambient and get a nice fill effect.
Hm, I don't know about this, your calculation seems off. There's just no way that a 1k 20ft away is going to do anything even on overcast day, especially if it's gelled. There was one shoot I was on where all we had was an ungelled 2k 5 ft from the actor on a close up and it did practically nothing.
Just to offer some objection, I'm not sure I will agree with what the others have said about needing HMI's to pull this off.
If you get in a forest on an overcast day, you are maybe going to get f8-f11 @ 800 ISO 1/48 24fps. I don't know how many hours you need to shoot, but if you shoot early in the mornings and in late afternoons you can definitely establish a working range of f5.6 to f11 with your ambient light. The time window would be limited for sure, but if you break your shoot into several days and plan your shots really well perhaps you can get what you need.
Having said that, for medium and close up shots an ARRI 1k tungsten will put out 105 foot candles at 20 feet using a medium focus beam.
I happen to know for example that my camera needs 42 fc to expose middle gray at f4. That means if I color correct the ARRI 1k and even lose a stop, I'm still getting 52.5 footcandles on my subject, or like I said around f4. That's 20 feet from my subject and on a medium focus setting.
If you make it more spot or move the light closer you're easily going to be able to get 1 stop over your ambient and get a nice fill effect. Go for a flat image on location, and more fill can be done on the skin in post if needed. It is really easy to do in your editing software alone incase you don't have fancy post production tools like After Effects.
Others have given some ideas.... one that just occurred to me is to use a portable green screen.
+1. We talk funny in the lighting bizthrow in some steel
Many things are hard to believe, but footcandles don't lie.
What light and camera were you shooting with? Again, the FC you need for your camera to get a certain aperture will depend completely on the camera and working ISO of it. My example was based on an effective ISO of 800. My guess is you were shooting with a stock camera like maybe HVX which was 320ASA if I remember correctly? Add a 35mm adapter and you were probably down to a working ASA of 80-160? I know, because I use to shoot with 35mm adapters too, but now using the Sony F3 which is 800 ISO. It is like friggin night vision.
