Audio for video I always go with 48k 16bit. Anything higher is overkill for dialog IMO, plus the headaches in the NLE.
There is a good reason to do that and channel offset is the reason. You set one higher and one lower and that way if the higher input channel is overdriven, you still have the lower channel as a safety net.
A lot of my mixes end up as mono anyway so I just center pan mono sources.
Dan
Plus, for location sound, 24-bit and high SPL mikes means more overhead for very loud/soft enviros....
....PS, If using 96/24 is a pain in your NLE, you're using the wrong NLE
To anyone who's got one, what are the pre-amps like on the Zoom?
BTW - it has 24 and 48v phantom...
Pre-amps are great with built in mike and phantom power condensers. With some dynamics a bit of hiss, but way less than previous zooms.
Samples here: Noise floor: http://www.wingfieldaudio.com/portable-recorder-noise.html#samples
Recordings: http://www.wingfieldaudio.com/portable-recorder-sound-samples.html
Does the Zoom H4N have an internal clock with date? Does it save the date and time the audio clip was taken to the file on the sd card?
