Chris Johnston
I just seem to notice a lot of people here shoot a lot of 720p60 vs 1080 with their dslrs. If not slowmo stuff is there an advantage to shooting 720? (resolution?)
though when shooting 720p/60, the recording time is longer per clip. That would be a big factor if they are needing longer recording times.
What's the recording time for 720? I seem to recall them both (720p60 , and 1080)being just a shade over 12 min.
It could be a matter of preference, though when shooting 720p/60, the recording time is longer per clip. That would be a big factor if they are needing longer recording times.
Is there a reason why you shouldnt shoot @ 1080, 60 for slo mo? I try to shoot @ 1080 all the time as i'd rather have more visible data just in case.. as well, if its noisy, resizing to 720 from 1080 compresses the pixels and should kill some of the noise.. similar to looking @ it on LCD and it looks great until you import it.
Well the only reason I can think of is that there isn't a 1080p, 60fps mode.
I do it all the time.. you're right there isnt a mode for it, but just set it to 24/30 so you can drop that low, then bump up your shutter speed prior to recording to 60..
One thing I've noticed, is that the 640P crop mode seems to have aliasing issues as well. I was shooting this red tin roof from a oblique angle, and it turned out weird as crap. Not as severe as the normal video mode, it also didn't have color moire, but it showed weird steps in the texture, it even showed this on the Liveview screen when I shot it, so I was eager to get home and see what was wrong, and sure enough, it was on the video as well.
