I then send a wireless feed from the H4n to all cameras for sync/monitor/backup audio purposes.
I use the standard way, via the H4n's "Line Out" to a Sennheiser G2 wireless transmitter.What do you use to send the audio wirelessly? A old rigged wireless mic, or something different?
Same frequency, multiple receivers (I have 4 complete wireless systems)And how do you port that into multiple cameras?
It's interesting that there aren't more people mentioning this kind of method as a recording option. I mean after all it's not too complicated a setup and pretty straight forward.Such a good idea. (Am I fawning enough?)
Actually if I ma just using the onboard mics, that is my preferred munting configuration. H4n on its side, with capsules rotated to 120 degree pickup pattern.thank you
Have you tried the mid-side option on the H4N? I'm guessing that you have to mount the H4N in a proper orientation to pull that off correctly... on it's side and at a 45 degree angle so that the mic designated as D and S are facing the way you would if you were doing such a setup. I haven't tried messing with that yet.
