jonathanrichards
If Jan is cruising these boards, does she know if Panasonic intend to extend their commitment to the Super 35mm large sensor format or is the AF100 a one hit wonder?
Panasonic is coming out with a variety of lenses for m4/3.
If they did its going to cost a lot of money... Then why not just buy a cooke zeiss or a real cine lens?Really, no kidding? What lenses that are specifically targeted for cinema use? Because if you mean these things that can't make smooth aperture transitions and that can't adequately talk to the AF100 and zooms that aren't parfocal, then I would say that Panasonic has turned its back on this camera... I know, Panasonic Pro doesn't make lenses. Tell that to the HPX250.
I have a really hard time seeing Panasonic going S35 anytime soon. 4/3 / m4/3 is a lot closer to the size of traditional 35mm film than S35, it's a format Panasonic has already made a commitment to that will accept a much wider array of lenses than S35, and Panasonic is coming out with a variety of lenses for m4/3. And honestly, what would the bulk of folks buying cameras in this price range get with an S35 sensor over a m4/3?
No, S35 is bigger than traditional film. The traditional cine film frame is 22 x 12mm. S35 does away with the optical soundtrack area and expands the frame size to 24.9mm wide. The AF100 is a little bit smaller than the cine film frame size, about as much smaller as S35 is bigger.What?
S35 IS the size of a traditional 35mm motion picture frame.
A lot of people are particularly not happy with the way that it handles highlights. Could you tell me if this is true. Does it have an issue? Apart from the FS100 having a far greater capability in low light, I don't understand how it is producing a better image.
Unfortunately, I see the next wave of cameras having the option of shooting at 1080/48p.![]()
As far as an AF-200 wish list, I would be happy with...
50MB/S AVCHD or higher
10-bit 4:2:2 w/ internal recording
Better overall image (you all know what that means)
SMALLER form factor.
And ideally I would like Panny to provide the option to remove things like built in LCD, EVF etc… but that’ll never happen. Apparently RED has the best kept secret in the industry that everyone knows about...
I would use an espresso maker function much more than any stereo/3D stuff.
