Chamber005
Carbonite Member
So I've been trying to get more into the technicals regarding sound, (Hz, Khz, dbs, etc). I've never had any real problems recording sound (keeping things around 0 dbs and always below 6dbs so as to eliminate distortion), but I've never really understood much about microphones other than their recording pattern.
Here's the schematics from a 25 dollar cardioid mic (CAD CM217):
Sensitivity: -53dB +/- -4dB @ 1KHz (0dB = 1V/u bar)
Output Impedance: 200 ohms +/- 20%
Frequency Response: 30Hz - 18KHz
Signal to Noise Ratio: More than 60dB
Here's the schematics from a 700 dollar cardioid mic (NTG-3):
Sensitivity: -30dB +/- 2dB (31.6mV/Pa)
Output impedance: 25
Frequency response: 40Hz - 20KHz
Signal to noise ratio: 81dB
The first thing that jumps out at me is the "Output impedance". 25 vs 200 (not sure what the 20% is about) which as I understand it relates to the voltage? I'm just hazarding a guess that the CAD would use a lower voltage than the NTG (so then 200 might be better than 25), but it looks like a lot of crazy math to me, so any elaboration would be great.
The frequency responses are pretty close, and while the signal to noise ratio is definitley greater on the NTG (again, not sure if that's a bad or a good, but I assume that it's worse to have a "lower" signal to noise ratio as the CAD loses this one as well), their numbers aren't too terribly far off from one another.
There's a -23 difference between the front sensitivity numbers. Does that mean that the CAD is more sensitive?
These two mics are completely different (though both can be used to record voice), which is kind of why I wanted to compare their specs -- so that I can hopefully understand what makes one mic's specs increase the mic's value over another.
