samyang 14mm f/2.8
it's also sold under a lot of other brands: rokinon, bower, opteka, etc
http://www.bhphotovideo.com/c/product/769532-REG/Rokinon_FE14M_C_14mm_Ultra_Wide_Angle_f_2_8.html
as all the other recent samyang lenses, it seems to be pretty good; here you can see how it compares with the 6 times more expensive canon 14mm f/2.8L II: the samyang has more distortion and more vignetting (at least on full frame), but it is actually sharper and has much much much smaller lateral chromatic aberration:
http://www.photozone.de/canon_eos_ff/532-samyang14f28eosff?start=1
http://www.photozone.de/canon_eos_ff/541-canon14f28mk2ff?start=1
it is completely manual, which for me is a good thing, but may be a problem for others
The Tokina 11-16 is worth the money.
+1
Canon EF-S 10-22mm for getting amazing wide shots
Eh, it's 1/2 to 1 1/2 stops slower.
It's not the slower stops, it's the shift between stops that causes a flicker in the image that's a problem.
So are you talking about exposure or image breathing? Are you trying to do zooms while rolling or ramping aperture?
No, if you zoom that lens, or any variable aperture zoom, the aperture will change in the middle of the zoom, creating a flicker in the video. So basically you can't zoom with the lens. The lens does that all by itself, and there's nothing you can do about it. That's why people here sometimes call them "variable primes" rather than zoom lenses.
Yes, I understand how that works, I'm just trying to remember the last time I did a zoom in a shot even with a lens that was designed to hold both focus and aperture. .
