With some of the NLEs starting to edit AVCHD nativly would I need lots of computer power compared to transcoding? Or would I need lots of computer power for both? Sorry for the newbie question.
I look at AVCHD as a container format...even if Final Cut had the ability to edit it natively, I still wouldn't cut with it. Plus, on my Mac Pro tower, transcode times are quick...much quicker than transcoding p2 media to DVC-PRO HD.
By Trasncoding to Pro-Res (or another codec), things just work better...and look really really purty.
LOL.... Joking right? No? hehe. I'm callin' you on this. BS. If you could put the SDHC card into a slot on your MAC and edit straight off the card with NO wasted time transcoding or transfering files for that matter you'd do it and be here telling us how great it is.
"Things just work better".... What if they worked exactly the same w/o transcoding? Then you wouldn't transcode!
AVCHD is a bad edit codec. So is MPEG-2. Your question is sort of moot.
The two possible AVCHD workflows are:
1) Quick news channel style chop and dice.
2) Frame accurate fine tuned edit with color correction and separate sound mix.
If doing 1, a native AVCHD w/o conversion is better, if doing 2 converting to a "fatter" codec is better.
When doing 1 - you'll consistently need CPU power to compute next frame.
When doing 2 - you waste the CPU power once when converting but will need more storage later.
I'm guessing you're doing short length, fast output to the net (sort of like number 1) and now have realised what a success story transcoding into ProRes422 from AVCHD is.
Some of these NLE's you describe are designed to do just that, a quick and dirty job. Like EDIUS Neo2, Avid News Cutter. The faster the better. Main target market is almost live shows and network news.
When was the last time you sent native AVCHD footage to a news room for viewing on the air?
That's my point that you apparently missed.
Sooner or later a transcode is involved.
For ease of editing, grading, titling, FX, multiple video layers, importing of other content creation, etc -- in other words, the editing process many follow -- most of us transcode.
Uh . . . sorry, I don't get the point.
I transcode once and then export. The export doesn't require a second transcode, nor any rendering.
Try creating some content in AE or Motion and bring it into an AVCHD native sequence?
You can't.
Actually, I will be doing weddings so I would love to transcode code into ProRes422. I also do wedding photography, so I would really like to put out high quality work fast so I don't get burned out editing video.
How do I transcode to ProRes422?
Would a really fast computer speed up the transcoding process?
Or does it even matter if I could just let it transcode overnight?
Thank you for the help!
