can you think of a test to determine if video recording is using color modes setting?
how can we find if it records in srgb or adobergb space? won't it make a vectorscope difference?
having picture controls to tweak colors and exposure on the internal raw instead of color correcting the avi is very good to have but i wonder if we can capture more colors in adobergb too.
I've mentioned it before but I firmly believe that something like Singh-Ray's Vari-Nd would be perfect for this camera. You can adjust for up to 8 stops. It's a great tool to vary and control the exposure.
The Vimeo videos by StoiQa look really good - just as good as my HV20 and Sgpro.
I'll be getting my D90 next week as it seems pretty sure that the new Canon 5D wont have a video mode.
I have the Vari ND and believe that it is the answer.
kholi, clean and sharp footage
and what are you like a thug? i mean your heat is just laying around like Gotti is gonna jump you.
here's some things you should know. i'll repeat a part from yesterday
- picture controls - the settings are not new on d90, all of them were available since the first digital nikon. the way they work has changed since 2007. before they were called picture controls the same setting on different cameras won't look identical.
that happens because each camera has a different sensor, with different color reproduction.
a saturation +2 on D80 won't look identical to a sat +2 on a d200.
since D3 and D300 these settings match every camera. you can create a look on a D300 and send it to a D90 user and i'll look the same. like a digital film type.
for photos PC make sense when using jpeg, not raw. raw is raw and you can alter any setting after the image is taken.
- custom curves - they map the internal raw to jpeg exposure conversion. instead of using linear you can draw your own curve to adjust exposure on shadows, midtones and highlights. more on this http://forums.dpreview.com/forums/read.asp?forum=1034&message=11239112 and here http://fotogenetic.dearingfilm.com/custom_tone_curves.html
you can emulate film tone curves by altering this curve. a neutral film would be linear, an agfa would have some compression in shadows and highlights and so on.
so using picture control adjustments you don't reach the jpeg compression and 8 bit limit when altering colors. don't do it in post if you can do it before compression and bit downsampling to avi. not to mention you can share the look with others and store them on the card.
when taking photos the color mode is important too. i'm not sure if this affects video but here's how it works on jpeg photos: color mode 1 and 3 are for portraits and landscapes. mode 3 is similar to a velvia film. color mode 2 is natural colors. 1 and 3 have an sRGB color space, 2 is adobe rgb. it would be best to use adobe rgb since it has a much wider color gamut. http://www.earthboundlight.com/phototips/nikon-color-modes.html
I found the information. Gonna have to load up the Nikon Console software now. I actually meant how do you create the custom curves, in camera or with external software and load it up.
With Photoshop CS3 extended it's pretty much there anyway. Interesting times.
Awesome stuff, especially considering this is handheld without VR :thumbup:
Vivid + Long exp.NR -On + Active D-Lighting-High + Exp comp(-1)...removed the iso)
