Duplicating Color Corrector on other clips
ShamrockFilms
I got color correction just the way I want it but the problem is its only on one clip. How do I duplicate the same color corrector settings to the other clips in the timeline without having to do each one manually again? Thank you.
1. Select and copy the corrected clip.
2. Select a clip you'd like to paste the color corrected attributes to.
3. Right or ctrl click and "paste attributes." You get a popup that allows you to select which attributes you copy. You'll want filters since color correction is a filter.
Another thing you can do is, after you've got a CC filter setup the way you want, you can drag it down into your Effects tab (like the favorites folder). Name it like "Bleach Bypass - Project X." So if you need the same CC setting, but you're using that aspects of a scene scattered heavily through out, then simply everytime you hit that clip you can just go to your favorites and its right there. But the aforementioned paste attributes is definitely the way to go highlighting all the necessary clips in one go is simple to do.
cheers.
If you already have the CC'd clip open in the viewer you can lasso all the clips you want effected and drag the CC filter from the viewer onto the group of selected clips in the timeline. Or if just want to add CC to the next clip in the timeline there is an arrow icon w/a "1" on it in the CC filter and if you press this it will copy the CC filter to the next clip in the timeline.
-A
