Tamron 17-50 VC
miloca
Hi guys,
I have the Tamron VC and I don't see any difference when using the VC option when shooting video with manual focus.
What about you guys? Do you get you footage smoother when using the VC on?
Cheers,
C
I couldn't imagine shooting handheld without the VC option. Maybe you have super steady hands!
Kegan
I wish I had steady hands. My footage is kind of shaky, but I wasn't sure if the VC works fine for video. I have been told it was only for photography. I guess I have to test it again with the VC on.
Cheers,
C
its not going to give you steadicam kind of shots but it makes a huge difference to getting rid of micro jitters. Easy way to see it at work is to use the 10x zoom feature on something and comparing it on to off.
I was coming to the forum today to post the same question. I have the non-VC version and was thiking about getting VC.
So Hunter007 and bimdas, it sounds like you guys have personal experience with this and are saying that VC makes a big difference?
Yes, I have the VC version and use it as my workhorse lens. VC makes the world of difference.
Kegan
Thanks Hunter for the input. I'll test it again tonight. I really thought it didn't do anything. I was told it was only when using autofocus.
Cheers,
C
Guys,
I tested it and it makes a lot of difference. I am glad i got the VC version, I was going for the non VC but it wasn't in stock. The lady at BH told me that's it wasn't worth the extra money, but now I guess it is worth it!
Cheers,
C
Glad you noticed the difference! It really does help eliminate microjitters that you might not necessarily notice during filming, but are blatantly obvious in post.
Kegan
tamron vc versus non vc 17-50
I owned the non VC version which I liked a lot, but for video, the VC version really required for decent footage (canon 7d) . So I sold the non VC vesrsion and am very happy with the VC model.
the feedback looks legit, but i was wondering if you guys spot anything wrong with it?
when it says canon mount, does that mean there's an adapter? or does it just directly mount onto the camera.
Third party lenses are made with different mounts for Nikon, Canon etc.
I was also looking at the Tamron 17-50mm. It looked pretty good, but can't get passed the VC version not being as sharp as the non VC version. I put the non VC lens on my 550D at the dealer, shot some tests and put them up on my computer. It was a nice lens, but I gotta say I wasn't blown away by the sharpness at 2.8. Just Ok. I also saw a very soft clip on another thread here on DVX last week, along with some reports of unsatisfied buyers returning them, so be sure this lens is what you really need before you spend your cash. I got the 50mm 1.8 for $99 bucks and neither Tamron will compete with it at 50mm at 2.8 for sharpness.
You can compare on the link below. Also compare to the Canon 50mm 1.8 at 2.8 and you'll see the difference in sharpness
1st link is Tamron VC at 50 vs Canon 50mm 1.8 at 2.8
2nd link are the 2 Tamrons side by side.
Buy sharp lenses and you will never want to sell them.
http://www.the-digital-picture.com/...p=679&CameraComp=474&SampleComp=0&FLI=0&API=2
http://www.the-digital-picture.com/...meraComp=474&SampleComp=0&FLIComp=3&APIComp=0
We all know prime lenses are sharper than zooms. Also it's not fair to compare ANY lens to the 50mm 1.8 as it is the sharpest lens that canon or any other manufacturer makes. No L glass or any other kind of lens will beat out the 50mm @ 50mm
It is completely fair to compare a $100 prime lens that is sharper then a $500 or $1000 zoom lens. I think everybody should know that fact.
I was surprised and happy to learn that the cheap little 50mm 1.8 in my bag stands up to most any lens out there.
The point is to achieve the sharpest image possible and to know what the options are. We're all here to learn and know the difference, so we can make the best lens selection, and find the great deals out there that produce amazing images while also affordable.
Some zooms are a good trade off, like the 17-40 L. or 16-35mmL. They are as sharp as the 20mm 2.8 prime and there are few other prime choices wider than 20mm, but in the mid range a Canon 28mm 2.8 for only $200 is another way to go for an ultra sharp image on a limited budget and a lens I will be sure to pick up on an impulse buy, just like I did with the 50mm 1.8.
DVXuser is a great resource for hands on information about equipment. I have made ALL my choices based on what I've learned here over the past year. Thanks to everyone.
I disagree with this statement 100% completely. First of all, all of these lenses produce a sharp image. Second Primes generally produce a nicer one but it's not all about sharpness.
Case in point doing a live even I need a Zoom lens, a 50 mm 1.8 would basically kill me. If I were also indoors doing a scene using a 50mm is not the most ideal situation. Finally I do music videos and when I want full body shots you can forget about dong that with a 50mm. You want to go handheld, forget about it. Car mount, forget about it and their are MANY more times that a zoom lens would benefit me over a 50mm prime.
Sharpness is NOT everything
Rockmore's second link is the interesting one, not the link comparing the prime.
Buyers should also be aware of quality control issues with tamrons. One tamron is not necessarily as good as another copy of the same lens.
For those that cannot afford VC, smoothcam is your friend
(I miss shake)
I agree, sharpness is not everything, but almost, aside from high resolution and low CA.
Using shallow DOF to create softness is another issue. This is a technique of choice and not the cause of limitations due to less than sharp lenses.
My post wasn't all about the 50 1.8. I used that to make a point about having a benchmark to compare other lenses to. It this case, a sharp and relatively fast lens everybody can afford.
Some zoom lenses have very poor sharpness and contrast at 50mm. The Tamron 17-50mm 2.8 VC has that flaw.
You know, I'm just trying to get to the bottom of what's a good investment for sharp glass. Nothing personal about shooting style, only the facts about the hardware.
This may be old news to someone with experience, but it's a good lesson for new members on this site who are looking to make good lens selections and have little experience and less cash.
Please show me any lens that is sharper than the 50mm 1.8 other than I guess the different f stop version of the same lens?
Sure when your filming a chart that sticks out, but on nature and peoples faces it's not that bad. I use the kit lens and have gotten a lot of great shots from it. To anyone looking to buy the VC version of the 17-50 don't put to much emphasis into these charts
Sure when your filming a chart that sticks out, but on nature and peoples faces it's not that bad. s
That's exactly right. The charts are just a clinical examination of the performance of the lens shooting a flat plane. The real world of photography is not like that. If you are shooting a portrait in the center of the frame where the lens is sharp it doesn't really matter that the corners get soft.
In the case of the Tamron 17-50 the design of the elements makes it really hard for the edges of the lens to focus on the same flat plane as the center, so in that lenses case a flat chart doesn't tell the whole story about what great images it can produce.
This is why it is very important to understand the design and behavior of a lens before you invest in it. I was about to buy the 17-50mm 2.8 non VC myself last week because it is not expensive and looked much sharper than the 18-55 kit lens I have, but didn't because I realized the benefit of the IS in my 18-55 kit lens may produce better hand held shots controlling movement, weighed against the sharper faster 17-50.
My point is, study your lenses and know them before buying them, look for the flaws and you won't be disappointed.
As far as what is a sharper 50mm lens than the 50mm f1.8 here are a few.
The new Planar T* 1,4/50 ZF went even further: It reached 320 lp/mm in the aperture range from f/5.6 to f/2.8, and 250 lp/mm at f/2.
What we are saying is this: Carl Zeiss lenses are capable of capturing enormous amounts of information, if required, and will not be the limiting factor in the imaging process. Knowing that the lens you are using is the strongest link in the chain always inspires confidence, and may be critically important in some cases.
