Barry_Green
Moderator
No, you're doing the math wrong. You've got it backwards.Since the GH1 is a 2x crop, the 7D/T2i is a 1.6x crop when compared to the 5D, mathematically, wouldn't there be a bigger difference in the DOF between a GH1 and a 7D/550D; then between the 7D/550D and the 5D??
The 7D/550D has a slightly larger sensor than the GH1, and the 5D has a sensor that's twice as large as the 7D/550D. The gap between GH1 and 7D is very small, you can equalize them by just opening up 1/2 stop on the GH1 as compared to the 7D. But the gap between 7D/550D and 5D is pretty huge, you'd have to open up the iris a total of 1.5 stops on the 7D to get equivalent depth of field
Not sure what you're watching; try "Depth of Phil" or "Shady, Texas" or any of Vincent Pascoe's work.From what I have seen on video, it seems the 7D/550d can achieve considerably shallower DOF than a GH1.
The 7D/550d can get a half-stop shallower DOF than a GH1, but that's it.
EDIT: hah, hadn't seen THIS thread... http://www.dvxuser.com/V6/showthread.php?p=2001343#post2001343
If that's accurate, then the difference between the 7D and GH1 might just be a little over 10%...
