If you want a full stable settings then go to Perfect Project threadany new stable settings for this version? I have a class 6 SD card? THanks
Where I can find Pappas Screen of Death?
Stable C settings for Manual lenses and Class 6 card
If you have manual lenses, a class 6 card, don't want 24/25pN, then these setting will work for you as they do for me.
Passes the Pappas Screen of Death and numerous other stress tests.
The 100% error free settings for me is ...
Version compare checked
Battery mod Checked
25pN unchecked
C settings
FHD/SH 50,000,000
H unchecked
L unchecked
Overall 52,000,000
Limiting Bitrate 60,000,000
Preset Bitrate1 - 234 (default)
Preset Bitrate2 - not ticked
Mpeg Settings are the ipowell 35mbps reliable ones with 422 checked
The absolute lowest the bitrate dropped to was 21mbps, the highest was 43mbps, Average was 27 - 34Mbps.
I shot grass, trees, pinebark, rocks, sand, tripod lock off shots, whip pans waterfalls, nothing gave an error.
I could not even get Pappas Star Chart to fail , so these are what i have settled on for now and given up completely on 25pN
Even using FHD/SH bitrate at 40 (limiting 44, overall 50) my class 6 card would fail in SH. Wouldn't fail in FHD.
My findings for extremely cheap Verbatim class 6 16gig SD cards in a GH1 -
Up to 28mbit works and seems to be stable (28m, 30m, 34m). The recommended settings for 32mbit (32m, 34m, 40m) cause the card write speed / crash error on demanding subjects.
Battery mod Checked
25pN unchecked
C settings
FHD/SH 50,000,000
H unchecked
L unchecked
Overall 52,000,000
In SH 720p mode the bitrates were overall lower by about 3-5 mbps
I don't believe a faster card will make any difference, 24/25pN is flawed in my opinion on any card.
This is part of the video of 40mbps files, both are 2 mins long no errors This is only a 30second sample
Video of Pappas Screen of Death ......... it kept recording for 5 mins then i turned it off. This is writing to a Class 6 card with FD manual lens 50mm f1.4 . My settings are completely stable with manual lenses.
Below is the ini file containing the settings above (delete the .txt on the end)
Ok ignore that, I forgot I had 25p enabled which causes it's own problems. I've just done a speed test with HD Tune on my sd card and it reports 13-14 MB/sec (not bad for the cheapest 16gig class 6 card on amazon). In theory that should be capable of 100mbps, I'm going to do some more test on my original test subject once the wind picks up (annoyingly it's perfectly still today)
rambooc1,
When filming Pappas' "screan of death" you should use the full screen image, the one you're testing against covers about 55% of the screen area which is not kind of "torture" test.
Has anyone tried dumping the bitrate of the audio, in order to squeeze out more image bps? I usually use separate audio recording gear, so the audio from the camera is redundant... the audio must use some bandwidth and cpu, and I was curious what image the gh1 could record if it wasn't working to record audio at the same time.
