Run&Gun
I should have specified that it had no *full* HD slomo. Maybe your clients are ok with a drop in resolution, but maybe only until a no-compromise camera is available...
That is understandable. I can get away with the resolution drop for a lot of things, but i just don’t like it. So, other than the 1DC, i never went for the C cams. Still think they’ve found a niche, but never been my preference.Why the ellipsis?
I had a lot of clients pass on my C300i when they wanted 1080 60p. I've had a lot of clients opt specifically for the fs7 because they wanted 4k 60p. And yes, I've had some clients settle for shooting 1080 60p for a 4k project on the C300mk2.
Having to downgrade the resolution to shoot slomo was always an Achilles heel of Canon cameras. In my view, a camera should be able to shoot at least 60fps in its maximum advertised framerate.
It's a mixed bag for me. For stuff I'm producing, usually I only receive a request for delivery resolution and possibly framerate. I could do whatever I want then and incorporate uprezzed off-speed stuff. I would consider that worth it if that higher framerate is needed.
For many clients, there may be a list or knowledge of acceptable cameras. Or they may want a certain brand in order to match footage (though obviously different models will not match perfectly). And sometimes they want a specific camera and, if the rate is sufficient, I can rent it if I don't own it.
The Komodo looks really cool to me. But I doubt it will be requested as an option instead of FS7/FX9/C300mk2&3/C500mk2. My guess is it will play as a RED B camera or the type of camera you can use when no one is asking. I owned a Scarlet years back but it wasn't a good money-maker because either people were excited to use it and had terrible budgets, or there was enough of a budget that renting an Epic instead was an easy choice. So I sold it and bought a C300 which worked out better even though the Scarlet had a better image IMO.
Why the ellipsis?
Re: Komodo. Definitely will be almost every Red owner’s Bcam. And car mount dream (no slanted backgrounds!), drone work! Stunt work, all of that, but i won’t be doing full readout slomo. At least not since i last checked. I don’t think it even does 60fps at full sensor. It will “only” have Helium level DR, and that will drop when GS is enabled.
Because I thought better after several minutes and decided to be a good neighbor and deleted my original comments and went and had a Klondike bar. I probably wouldn't have made the original comments I went back and deleted, if the other post had been like the one I'm responding to now. ; )
Anyone have experience with the BMPCC4k or 6k?
About half of the world...what would you like to know?
The *one* thing I wish it had was a 12-bit H265 codec - does that exist?
FWIW, some YouTubers will upload in faux 8K to avoid some of the compression artifacts but then someone would have to watch it in 8K as well.---I think YouTube would help you for the above. Even with the compression, you'd hear and see various results/thoughts.--- .
There's even 16 bit.
Truly random...it's not something you can anticipate or control; it's something I've never seen before in other cameras. Sometimes you'll be filming and a bunch of static just starts dancing on the screen or green lines randomly flash in the corners, and then sometimes you'll come home with 300 perfect clips. Over the years, a lot of people on forums have written about this random corruption (it comes and goes), but there's never been an answer besides RMAing the camera if possible (but what's the point if the next one may do it too).
Heat? Software? Hardware? Media slowing down? Writing to a bad portion of media? It's unknown...
