After extensive testing of this camera, there seems to be something wrong with the sensor. While on and recording video, the resulting footage, gimbal stabilized, with or without IBIS on, has sensor rattle sounds in it. The internal microphone is picking up the sound, which is quite loud. It’s also audible just holding the camera in my hand. I first thought it was the knobs on the gimbal so I taped them all down. Still rattling. Then, next I thought it was the camera strap triangle latches, so I removed them. Still rattling. So I took the lens off the camera, only body remaining, and with the camera on, gently shook the camera. Still rattling. I looked at the sensor and I can see it knocking up against the inside of the camera.
As I mentioned before in my other thread about this, the footage, if not using a gimbal, is completely unusable. Even with the gimbal (the Ronin-S), it's MUCH smoother, but there's shaking going on in the video.
Those who own the GH5, are you hearing the sensor rattling when on and recording video if you gently shake or move the camera?
Here’s a video I made a couple days ago where this can be heard in the resulting footage after being recorded using the Ronin-S.
https://youtu.be/2UES5VKcfAQ
Here’s a video someone else made who was having the same issue.
https://youtu.be/PnkuHC27nA0
