This loupe does not use adhesive or magnets but has an adaptor that uses the tripod screw. You would need to remove it to use the articulated screen open http://cgi.ebay.com/2-8x-LCD-viewfi...rs_Eyecups&hash=item20b9682780#ht_4087wt_1149
The current model Zacuto Z-finder that uses the gorilla plate should allow you to switch from using the loupe to the swing out screen quickly but Zacuto note that "The gorilla plate covers the battery compartment door on the Canon T2i Camera." & to use the adhesive plate if this is a problem.
I just received mine today & can confirm that it does fit my 600D (T3i). The optics are OK but the large eye cup is rather hard rubber & there is no dioptre adjustment. I think that I may cannibalise it with a GGS loupe as that has very nice optics, a dioptre adjustment & is more comfortable. All I need to do is stick the plastic frame of the GGS onto the metal frame of this one & then I can click the loupe on & off. It mounts & dismounts quickly & easily from the tripod screw-hole so it only takes seconds to swap out the loupe mount & swivel round the articulated screen when required http://cgi.ebay.com/GGS-3X-LCD-View...ccessories&hash=item20b811692a#ht_5911wt_1149This loupe does not use adhesive or magnets but has an adaptor that uses the tripod screw. You would need to remove it to use the articulated screen open http://cgi.ebay.com/2-8x-LCD-viewfi...rs_Eyecups&hash=item20b9682780#ht_4087wt_1149
Even better is the Hoodman "Cinema Pro Kit". Hoodcrane,
bumping this thread, i'm currently looking for an affordable (under $100) option for a viewfinder/loupe for the T3i.
Anyone knows the the ones that attaches directly to the screen would produce any problems with the LCD flipped out? Would it be dangerous on the hinge or are they light enough to not worry about it?
This model seems like a good option for example: http://www.amazon.com/NEEWER-DSLR-Foldable-Viewfinder-Magnification/dp/B004HD3G6Q/ref=sr_1_1?ie=UTF8&qid=1324403999&sr=8-1?&tag=din0a-20
thanks for any help or recommendations.
eiker_ir,
I purchased this on Amazon and it works nicely with my 60d: http://www.amazon.com/gp/product/B004RG4MNE/
I did not use the adhesive frame, rather I also purchased the neoprene wrap referenced by Pete: http://www.amazon.com/gp/product/B005OU4Q9W/
I do not have any issue with the weight using this on my 60d with the LCD flipped out, I am careful though.
Alternately, you could purchase this version as the frame attaches to the tripod mount instead of the adhesive method: http://www.amazon.com/gp/product/B004RG4IIS/
I hope this is helpful.
Regards,
Aric Spence
DSLR Solutions
http://www.dslrsolutions.net/
