Just found this one. It's pretty bad and I could consider this 100% unusable.
If I hired someone and they brought me back this footage, they would be beyond fired.
http://blip.tv/file/703191?filename=Jetset-specialWhatFilmmakersReallyThinkOfTheWeb273.flv
EDIT: i'm not sure what camera this is from, i did a search and this thread came up, i didn't even know this was in the Sony EX-1 section
At the end of the day, Rolling Shutter CMOS technology (or at least its ill-conceived deployment in video and motion picture cameras) looks set to take a podium position among the greatest technology stuff ups of the 21st century... it's certainly winning the race for this decade. Hopefully it wont be around to be a contender in the next.
And film has issues with strobes that aren't synced, as pointed out earlier. However, since the shutter is some physical distance from the film plane and out of focus, the effect isn't as nasty. Here's a couple example from the movie Pitch Black showing this...
That its bearable with the RED is only because of the vast host of other benefits it brings to the table, and because the issues of the rolling shutter on that model will eventually be addressed.
This is not what I used - but it's probably the most elegant solution. Strobes would need to be compatible with the accessory output:
http://www.cinematographyelectronics.com/index_gallery.html
Needless to say, this is expensive. But rentable at most 35mm camera houses.
When I did it, I used something far more cumbersome, but it definitely worked - it was a motion control computer (not connected to a motion control system - just standalone):
http://www.kupercontrols.com/
Also expensive.
I agree and it's too bad that people have such extreme views about cameras, as if Camera_A is perfect, but Camera_B is total junk. Anyone who questions this goes to digital hell...
I've seen outstanding work created with the HVX-200 and I'm starting to see outstanding work created with the EX-1. Both cameras have strong points and both cameras have weak points, STILL users are able to produce great results with either camera. It's all a matter of person needs and wishes that defines which camera it best for each person.
A camera is a tool and just because someone selects a different tool from others, that does NOT make them a better or worse person than someone else.
Bob Diaz
