snodart
In my experiences, a motor that makes the GG move in a circular motion gives the best results at high f/stops and in lower light. You can test this if there is a small spec of dust on your GG. Crank the 35mm lens to f/11 or f/16 and turn the motor on. If the dust spec turns into a small circle then you will be good to go. If the dust spec turns into a line or a very narrow oval, then images at higher f/stops and in low light will show the pattern that the moving grain is making. The bigger the circle, the better... so long as the vibration doesn't make its way to the camera too much. This is one advantage of having the GG at some distance from the base... it allows the GG to make larger circles. Each circular patter of grain overlaps the others and also spreads the grain out over a larger area. Just something to think about as you refine your design.
