Park Edwards
It's still unclear to me why and when I need to check version compare and prevent version check.
I'd like to understand the mechanics behind this and how I should be careful with it.
Thanks a lot in advance.
Version Compare was the first tool designed so you could you use the hack over and over. Panasonic doesn't allow you to roll back. It's either up or nothing.
When the first ptools were introduced Version Compare had to be incremented each time you loaded the patch. A lot of people were too scared that the patched firmware would ruin their camera and could never send it back to while still under warranty and were too illiterate to read that you had to increment each time you loaded the patch. Then came Prevent Version Check.
The title itself defines the purpose of this patch. Upon loading Prevent Version Check this does two things. First it eliminates the need to use check Version Compare once the patch has been loaded with Prevent Version Check. Secondly, it modifies the firmware so in case you are among the those who too worried they couldn't default back to panasonic's factory firmware, you could. It essentially tricked the camera into going to a 0.0 firmware so anything above 0.0, could be loaded.
You only need to check Version Compare one time, as long as you loaded Prevent Version Check simultaneously. From there after, each time you feel like you need to change something in the patch, just check Prevent Version Check.
A good way to tell if you need to check Version Compare anymore is to look at your firmware version in camera. If it reads 0.0, then skip Version Check and continue to keep loading Prevent Version Compare.
If from here on out you still don't get it, it's best you didn't load the patch.
