You can't use the camera to write the presets to the camera. An SD card reader would certainly work fine although I use my laptop which has an SD slot. Another way is to put the card in a digital photo camera that uses SD and hook it up via USB. Then you just find the camera in "MY Computer" and write the presets to it.
As far as 4 of the presets apping when 20 are loaded onto the card, that's very odd. The camera has 9 built in presets that you should be able to scroll through. When you get to number 9, it should start over at 1 again and go to 20. Are you sure all the presets were properly named with the correct extension Nasser?
