Panasonic reveals more details of AG-AF100
Compact Flash is also pretty rugged.. And much cheaper! Panasonic should ditch the P2 cards and make all their cameras Compact Flash compatible.
Why do you want recording on P2 cards? They are very expensive!
This has been beaten to death 8 time over... but while I personally don't need it, there are definite advantages with P2 for a large segment of the potential customer base (not the least of which is AVC-Intra). A lot of the folks looking at this are coming from cameras like the HPX2700, so they either already have P2 and are invested in the workflow, or are looking at this and thinking that, given the competition, even with P2 the camera would be a downright steal.
Without going into engineering (because I'm not an engineer) P2 is absolutely bullet proof. Period. CF and SDHC aren't. The costs don't make the advantages worth it to me for what I do, but I'm not so foolish to believe that what works for me is what works for everyone else.
No, they're not (at least compared to P2). I've never heard of someone losing footage from P2 because their card crapped out. I've heard of plenty of people that their SD card died in the middle of a shoot or the pins on their CF card broke in camera or something like that.
Maybe you should tell RED about this so they can ditch those crappy CF cards and switch to P2.
Enough with the CF vs P2 argument, it's been done to death. Panasonic will not ever go CF, because it's not a suitable medium for professional video, in that it doesn't even have a write-protect tab on it. Whether Red (or Red users) find it suitable is irrelevant, Panasonic has laid out their reasons, and their decision is made.
RED is not the end all to be all of cameras. I don't see too many news crews running around with REDs. RED serves a certain niche market, and by most accounts they serve it fairly well. But to assume that the needs of a RED user is the same as the needs of a news crew, or someone out in the middle of nowhere shooting a Planet Earth/Life type show, or "The Office" is extremely short sighted and borders on arrogant. Don't be so foolish to assume that what works for you works for everyone else.
If you prefer CF, go get a camera that shoots CF (or SDHC, like what I own). But Barry is right, enough with the "Panasonic should go CF and ditch P2". It's been beat into the ground a thousand time over, and Panasonic has their reasons for not going that route. And thousands of customers when given the opportunity have chosen to stay with the format.
Buy the tool that best works for you, but don't tell everyone else what works best for them. Don't assume you know best what everyone else needs/wants/should have.
(And by the way, I never said CF was crappy... only that it isn't as bullet proof as P2)
Is there a thread (don't want to derail this one ) about 1.8" SSDs? I was wondering how good those would be as a video camera media standard.
Pros:
- Right size. SD is so small it's dangerous to lose. I think this size is ideal.
- Commodity hardware
- Fast (SATA II = up to 3 gigabits per second)
Cons:
- connectors too fragile?
- ______________________
Some SSDs will work, but they need repacking to a connector with better mechanics. Many companies gross millions on their vendor specific media, so I doubt they would switch to something based on SATA.
Red is doing that for their new cameras, putting on their own connector and everything.
Adding a connector makes the media assembly vendor specific. It can be sold at 200% margin unless the casing with the new connector is available in the open market, so SATA is viable.
So is this going to be the same implementation of AVCHD codec as whats on the HCM150, only with a higher bitrate?
Also what's the expected in-stores date now? December or before?
It will likely be the same as on the HMC150, HMC40, HMC80 AVCCAM cameras. I don't know whether it will have a higher bitrate or not; the HMC150/40/80 already max out what AVCCAM can do.
Only thing we've heard is by the end of the year.
The 1080p60 option of the TM700 isn't AVCCAM (or a "simple" upgrade to it)?
The 1080/60p isn't AVCHD at all, it's outside the spec.
AVCCAM is a brand name for a specific flavor of AVCHD, plus the metadata, plus the camcorders that use it, the warranty, all that stuff. But the underlying footage is entirely AVCHD-compliant.
What the TM700 does is it shoots AVCHD in the lower-bitrate AVCHD-compliant modes, and then it has a separate custom h.264 mode for shooting 1080/60p in.
