They may be expensive but worth every dollar you pay. I'd personnally rather shoot on a rugged and dependable storage device that never fails during a critical shooting like P2 than a flimsy plastic media like SD. Heard too many horror stories out there.
Can't wait to try the AF100 though, I really hope all the features Barry's mentioned end up in it!
In all seriousness -- the not-cheap SDHC cards have been exactly as reliable as our two P2 cards -- the two P2 cards that have spent most of the past year and a half in a box with the HPX170 because the HMC150 was ideal for most things for a range of reasons.
If the AF-100 will record redundantly to both card slots that should eliminate any card failure issues.
Not to get off topic but can I ask why you chose to use the HMC150 over an available HPX170 when you did? Are there any advantages other than being able to record longer in the field and being able to archive smaller footage? Granted these are big advantages for myself, I'm just curious if there are any other pro's to the HMC150 over HPX170.
This I totally agree with. I've been working with AVCCAM in my HMC40 and HMC150, and it's really surprisingly good, all things considered. No, it's not AVC-Intra, and yes I'd rather have AVC-Intra. But AVCCAM is a better, more robust codec that XDCAM-EX and substantially better than XDCAM-HD. It's dramatically better than HDV.but in a larger sense the bottom line is that AVCCAM really doesn't suck -- and will actually be a rather pleasant surprise to the people who first encounter it with the new AF-100.
Heh. There's an old saying that goes "If you have to ask the price, you can't afford it."I think it's the one you can see on this bottom of this Zeiss .pdf
But I can't find a price for it anywhere..
Interesting -- they list a date of December 1st on there. Wonder where they got that date... if they're just guessing, or if they've actually been told that by Panasonic Europe?She is getting closer...and closer...and she is beautiful....!!!
And variable frame rates
And HDMI output
And a headphone jack
And audio outputs
And live monitoring while recording
And timecode(!)
And metadata
And two card slots
And 7 different gamma curves
And Dynamic Range Stretching
And complete image control instead of limited consumer image tweaks
And 1080/60i and 1080/50i (for those who want it)
And focus assist that can be used while recording
And zebras
And a waveform monitor
And a vectorscope
And a spotmeter "marker"
And manual audio level control
And the ability to disable all Audio Gain
And higher-quality audio pre-amps
And color-matched with the other Panasonic pro cameras like the VariCams
And 48KHz uncompressed audio recording
And built-in optical neutral density filters
And Pre-record
And an intervalometer
And different aspect ratio markings in the viewfinder/LCD
And much cleaner/sharper images with the elimination of all aliasing and moire
And peaking for easier manual focus
And (as said before) a much more robust recording format (AVCCAM PH mode)
And variable shutter angles from 1 to 360 degrees
And syncro-scan shutter in video mode (infinitely-settable shutter from 1/24.0 to 1/250.0)
And manual black balance capability
And selectable color matrices
And adjustable knee point and master pedestal controls
And the ability to assign index points within clips
And the ability to mark clips "good" or "no good"
And the ability to delete the last clip you just shot
And maybe the ability to time-stamp your footage if needed
And a 90% "safety zone" for making sure your framing will be visible on all TVs
And the ability to take much larger batteries
And the ability to assign user clip names to the clips that get shot
And the ability to use a wireless infrared remote controller
And the ability to generate color bars
And maybe the ability to take remote zoom/iris/focus/stop/start controllers
And the ability to save and exchange scene files, for instant/easy matching between multiple cameras
